need some advise with turbo hitting block
Old Aug 28, 2003 | 03:33 PM
71 mgb's Avatar
Default need some advise with turbo hitting block
i am putting in a turbo (t3/t4) and i have ground out the webbing on the block but the compressor is still tuching the block.... i dont know what to do anymore.... will it affect anything if thare is no clearance ???? my other option is to make a spacer for the flange so it will push the turbo back a bit???
what would u guys recomend??
thanks
chris
Old Aug 28, 2003 | 03:45 PM
dualknuttz1's Avatar
Default Re: need some advise with turbo hitting block (71 mgb)
It's worth a try but maybe you can add another gasket inbetween the turbo and the manifold, or better yet maybe another manifold gasket between the head and the manifold. I don't know how many gasket you might have to use. Just a thought though.
Old Aug 28, 2003 | 04:51 PM
W.Zero's Avatar
Default Re: need some advise with turbo hitting block (dualknuttz1)
what about grinding the block more? my turbo hit and so did my boy, all i did was grind the block till it didnt hit.
Old Aug 28, 2003 | 04:57 PM
trbob16a's Avatar
Default Re: need some advise with turbo hitting block (W.ZeroB18C1T)
I have never understood this. Almost everyone running a turbo honda is having a custom downpipe made anyway. Turn the turbo around (clock it) and have the inlet facing the drivers side. Problem solved. The people that fabricate your downpipe won't care and you won't have to grind anything.
Old Aug 28, 2003 | 05:13 PM
igotyofire's Avatar
Default Re: need some advise with turbo hitting block (trbob16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trbob16a &raquo;</TD></TR><TR><TD CLASS="quote">I have never understood this. Almost everyone running a turbo honda is having a custom downpipe made anyway. Turn the turbo around (clock it) and have the inlet facing the drivers side. Problem solved. The people that fabricate your downpipe won't care and you won't have to grind anything.</TD></TR></TABLE>
how come not alot of people do that?, turning the other way, wouldn't that affect AC and that stuff if your manifold allows you to keep ac ?
Old Aug 28, 2003 | 05:59 PM
trbob16a's Avatar
Default Re: need some advise with turbo hitting block (igotyofire)
A/C is the reason, you're right... I guess I just figure people wouldn't mind getting rid of it.
Anyway you can probably keep shaving, I've seen some block/tranny with a whole lot taken off and they were OK.
Old Aug 28, 2003 | 06:43 PM
W.Zero's Avatar
just keep shaving. you flip it youll have trouble with a filter.
Old Aug 28, 2003 | 07:46 PM
InTeGrA B18b1's Avatar
if you have a drag manifold i know you have trim teh fan alot. thats how i got my hybrid in
Old Aug 28, 2003 | 08:01 PM
71 mgb's Avatar
Default Re: need some advise with turbo hitting block (InTeGrA B18b1)
thanks for all you help but i just found some scrap 3/16 steel and am making a spacer... and for the ppl that said to shave the block away more, if i did that i would have a big whole....... i will post some pics of the spacer and all the triming i had to do...
chris
Old Aug 28, 2003 | 08:41 PM
SiR Kid's Avatar
New User
I seriously doubt you've done as much grinding as I had to do, and I don't feel like I compromised the strength of my block at all...
Let me scrounge up my old post.
Also, I couldn't flip my turbo around, because the turbine side would have been IN the radiator. ED chassis = NO space!
https://honda-tech.com/zerothread?id=510830
Old Aug 28, 2003 | 11:03 PM
igotyofire's Avatar
Default Re: need some advise with turbo hitting block (SiR Kid)
so is it only people with b16s having problems, arent people with b18c's having problems with turbo hitting the webbing also, i was reading one of the links in their from Art's old post, and said somthing that if people choose the correct manifold and turbo they wouldn't have this problem?
Old Aug 29, 2003 | 11:49 AM
71 mgb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Kid &raquo;</TD></TR><TR><TD CLASS="quote">I seriously doubt you've done as much grinding as I had to do, and I don't feel like I compromised the strength of my block at all...
https://honda-tech.com/zerothread?id=510830</TD></TR></TABLE>
my turbo is hitting a dif part of the block... mine was hitting to the right of the plug wear the block heater goes....im pretty sure thats a colent passage so i didnt want to grind it away...
D16SohcVtec
Mar 31, 2009 06:38 AM
BOOSTEDgs-R
Feb 18, 2008 09:47 PM
meams
Jul 21, 2004 10:40 AM
