Turbo spool
Old Aug 29, 2003 | 04:40 PM
hotboi850's Avatar
Default Turbo spool
I finally finished my turbo install. Took it for test drive and I gotta say my HKS SSQ sounds damn nice. hehe loud. psssshhh. But anyway, I have a T3 turbo and I get full boost around 3k RPM.
Now when im cruising on the highway Going about 70- 80mph. My RPM's are usually around 3k. I'm assumming I'm gonna get boost all the time since the turbo spools up around that range.
What do u guys do when your taking long road trips? I sure dont wanna be boosting all the way for a 6hr drive.
Old Aug 29, 2003 | 04:43 PM
boosted92's Avatar
Default Re: Turbo spool (hotboi850)
You won't be boosting as long as you're not hard on the throttle.
Old Aug 29, 2003 | 06:42 PM
PureTeg420's Avatar
boost is dependent on exhaust flow, not on engine rpm
Old Aug 29, 2003 | 06:51 PM
TeStUdO's Avatar
Default Re: Turbo spool (PureTeg420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PureTeg420 &raquo;</TD></TR><TR><TD CLASS="quote">boost is dependent on exhaust flow, not on engine rpm</TD></TR></TABLE>
exactly, as long as you arent under a load cruising at 60 or 70 you wont boost.
Old Aug 29, 2003 | 06:57 PM
hotboi850's Avatar
interesting. thanks!
Old Aug 30, 2003 | 06:21 AM
Code Blue's Avatar
Default Re: Turbo spool (TeStUdO)
you actually want this, so if your traveling on the highway or etc you can actually get somewhat decent gas mileage
Old Aug 30, 2003 | 07:06 AM
meanteg's Avatar
New User
Default Re: Turbo spool (Code Blue)
the turbo will spool with load , so you can have zero boost at 6000 rpm if you want .
Old Aug 30, 2003 | 08:39 AM
Foozball26's Avatar
Default Re: Turbo spool (meanteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meanteg &raquo;</TD></TR><TR><TD CLASS="quote">the turbo will spool with load , so you can have zero boost at 6000 rpm if you want .
exactly, its not equal to exhaust flow.
exhaust flow is only half the equation.
Old Aug 30, 2003 | 08:59 AM
lazerus's Avatar
Default Re: Turbo spool (Foozball26)
though even though the turbo will not be spooled it will be nice because for power all you have to do is roll your foot on the gas :-)
farcie123
Oct 22, 2013 09:18 AM
djwest24
Sep 20, 2004 07:12 AM
mrx
May 12, 2004 11:20 AM
SimonsTeg
Oct 31, 2002 10:41 PM
OKSolSi
May 20, 2002 04:31 PM
