ACT Clutch Break In with boost?
Hey,
I ordered my Drag III kit and my ACT clutch at the same time, and I plan on getting them installed at the same time. Is it safe to have a properly broken in clutch with boost running? Even if I stay below 3500 RPM or so? I plan on only running stock boost levels. Would you reccomend getting the clutch installed, breaking it in, and THEN installing the turbo kit? Thanks
well it depends on what disc you got. if you got the 4/6 puck you dont need to break it in, but if you got the full face, then you need to take it easy for about 500 miles
