JE pistons and honda rings??? why they dont fit?
Ok have a set of JE 84mm pistons for a b20 and need to replace the rings. So i ordered stock honda rings, but the top ring will not fit in the JE piston. whats the deal? Its like almost the right size just a mm or 2 off. Did honda get me the wrong rings? Also does anyone know the honda part number of the piston rings that will fit these pistons? any help is apriciated
Re: JE pistons and honda rings??? why they dont fit? (ekb18c)
turboex posted this for me.
the rings i have are for a 97 crv. part # 13011-p3f-003. the wierd thing is that only the top ring doesn't fit. these are stock honda rings that i'm trying to put on 84mm je pistons. is the top ring on a b20b and a b20z different. the b20z part# is 13011-phk-003.
Re: JE pistons and honda rings??? why they dont fit? (torr)
I think it would be correct if the JE pistons call for a slightly thicker ring that will be more durable for forced induction/nitrous applications.
I would recommend trying to get a set of rings from JE, the composition of the rings will probably be made from more durable materials than stock.
well then i was wrong about that notion.
i still would recommend getting a set from JE, or a piston ring manufacturer using JE's ring specs.
Unless spec'd otherwise. The JE piston uses a top ring 1.0mm thick, and 2nd ring 1.2mm. JE or Wiseco can supply rings. Doubt top only though!
Jim
Jim
b20vtech
05-10-2007 06:23 PM
