how much hp can 96lb injectors handle
I currently have 96lb injectors and i am thinking that i may be cutting it too close with fuel. I have access to a set of 160lb and know i can tune them in. We had a conversation with Jobe (from Turbo People, i think thats his name ) about this and he told us that 96lb is more than enough. The problem is i do the math and it dont add up. Has anyone maxed out 96lb injectors or have an idea of how much power they are making and have the duty on the injectors.
BTW i am using 4 injectors
Re: how much hp can 96lb injectors handle (boosted3g)
there are many variables to consider...but in general i at least know that 72lb injectors should be good for around 450-500hp.
New User
your math might be skewed by forgetting to factor in the raise in fuel pressure (1:1) with most regulators. 96lb (roughly 1000cc) injectors are good to like 700whp so long as your fuel pump can hang and your line size is sufficient
Modified by VaporTrail at 4:14 PM 8/31/2003
Re: how much hp can 96lb injectors handle (VaporTrail)
Hey Josh with what kinda power you wanna make, youmight be cutting it close, you can up the fuel pressure tomake the difference up though.
BTW im looking for 960's soif you decide tosellthem hook up with me, illprob take em if the price is right.
You getting Harry's injecotrs?
Re: how much hp can 96lb injectors handle (itr206)
I plan on going to about 700 whp as long as everything holds together. I have a huge Barry Grant pump so getting enough fuel wont be the problem. Pete ill get ahold of you about the 96's i would rather go bigger since im planning on adding a little meth to the fuel. Also youll have to check out my new PT74, got rid of that little TE64
EGed up from the seat up
17
07-02-2009 12:16 AM
