Turbo parts needed to run low psi?
If i get a turbo t4, then what will i need to run it at low psi?
Piping
Boost controller
what else, i know theres more, just thought someone with experience could fill me in.
Thnaks
Piping
Boost controller
Thnaks
Re: Turbo parts needed to run low psi? (Mnintegra)
a t4 for low boost might not be the most efficient way to go if you are just looking for a regular moderate hp 'kit.'
other then that, you will need:
fuel pump (inline or intank) - i actually have a bosch inline for sale if you need one
fmu
intercooler - you can get away without one for LOW psi (3-4psi) but i dont recommend it
downpipe
manifold
wastegate (if turbo is an external wg)
oil feed lines - i have some NICE braided ones with brass fittings if you need them
oil return line
hose clamps
vacuum line
vacuum t's
edit: blow off valve
There are a few other misc things left off, but thats about it. Also, try doing a search on turbo kits to learn some more about them before you invest in one.
Modified by GudeH23a at 4:41 PM 8/27/2003
fmu
downpipe
manifold
oil return line
hose clamps
vacuum line
vacuum t's
Re: Turbo parts needed to run low psi? (GudeH23a)
This could work:
-Chipped ECU
-Larger Injectors
turbo
blowoff valve
downpipe
manifold
oil lines
blah blah
blah search...
-Chipped ECU
-Larger Injectors
turbo
blowoff valve
downpipe
manifold
oil lines
blah blah
blah search...
. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mnintegra »</TD></TR><TR><TD CLASS="quote">is a chipped ecu and injectors needed for low boost tho?</TD></TR></TABLE>
Nah, and like the other dude said, a t4 is probably not a good choice if you're set on low boost.
You do need some sort of fuel control with any turbo setup tho. You can't just bolt it on and expect your stock fuel system to compensate for the additional air
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mnintegra »</TD></TR><TR><TD CLASS="quote">If i get a turbo t4, then what will i need to run it at low psi?
Piping
Boost controller
Thnaks</TD></TR></TABLE>
Boost controller
Won't help you get a lower psi
Piping
Boost controller
Boost controller
You sure as hell do need a boost controller, otherwise you...won't have controlled boost.
There are a whole ton of things you might ned, you can't really just ask for a list.
Don't use a T4.
Don't use a T4.
Honda-Tech Sponsor
I agree. A T4 at low boost is far out of its efficiency range. If you are going to run big boost later, then it's fine.
Until then, I'd get a small t3/t4 or a mitsubishi turbo.
Man, you guys in this post are really helpful.
I posted something similar but only received one good respons.
Keep up the good work.
https://honda-tech.com/zerothread?id=602988
Re: (kpt4321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpt4321 »</TD></TR><TR><TD CLASS="quote">You sure as hell do need a boost controller, otherwise you...won't have controlled boost.</TD></TR></TABLE>
If you don't run a boost controller, the boost is 'controlled' by the wastegate setting. You don't HAVE to have a boost controller. Like the other guy said, all it can do anyways is raise your boost level, not lower it. This guy doesn't need one.
Re: (mos)
Thank you, there are ways to lower your boost though,
http://zoogle.zapto.org/wastegate.jpg
http://www.homemadeturbo.com/f...=2952
If you make it so that you can set the boost lower than the wastegate spring pressure, then you will have to have a system which bypasses exhaust gas even when not in boost, and thus you will increase lag and raise the boost threshhold.
The wastegate spring pressure is as low as you can go, if you don't want the car to suck.
You can use a pressure source directly on the wastegate instead of using the boost controller, but that brings us back to the sucking thing. That will allow a pressure signal to reach the WG and open it befoe you reach full boost, slowing down boost response.
Tr0LL
08-30-2001 05:51 PM
