Its about TIME! many pics
I would route my coolant hose away from the manifold. Just make a metal hardline that routes it away from the extreme heat that manifold WILL make!
Looks good...
I dont really like the charge pipe that sits right next to the downpipe. Even with the downpipe rapped, there's going to quite a bit of heat transfer into the boost tube. Just a lit constructive feed back for you
-Justin
-Justin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nigel »</TD></TR><TR><TD CLASS="quote">so does that manifold perform as well as it looks? what are the benifits to having a sidewinder mani like that? </TD></TR></TABLE>
He will find out once its tuned, the manifold paired with the larger bore turned the plugs white just putting around the block, obviously not a safe combination. Derron says the turbo spools up on idle though
and it never used to(smaller turbo, w/smaller bore)!
For installation, Derron said it was a PITA, because the turbo pretty much sat on the tranny mount. This has since been corrected with the base jig(moved the turbo up an inch, and to the drivers side a weee bit), and there will be no cutting involved in the future. Derron was more or less a "tester" if you will
The purpose of this manifold is the ability to run AC w/minimal modifications, and make the most power possible because of a full 3 inch DP(maybe 4", like some people are doing already).
and it never used to(smaller turbo, w/smaller bore)!For installation, Derron said it was a PITA, because the turbo pretty much sat on the tranny mount. This has since been corrected with the base jig(moved the turbo up an inch, and to the drivers side a weee bit), and there will be no cutting involved in the future. Derron was more or less a "tester" if you will
