3 bar map sensor?? help!!
Old Aug 27, 2003 | 03:49 PM
BLACKLUDE97's Avatar
Default 3 bar map sensor?? help!!
ok, i have a 00 turbo civic si. i just finished getting sleeves, rods, pistons , and i just got the aem ems. i plan on boosting 22 psi and i hear i need a 3 bar map sensor? i dont know what to do. do i need one? where do i get one?? help me out guys. thanks
Old Aug 27, 2003 | 04:54 PM
11psiTurboSI's Avatar
Default Re: 3 bar map sensor?? help!! (BLACKLUDE97)
if u plan on running more then 11.2psi you need a 3bar map sensor from GM... if you do a search you will find the part number and a website you can purchase it from! i just ordered mine yesterday for my hondata
Old Aug 27, 2003 | 04:56 PM
Default Re: 3 bar map sensor?? help!! (9psiTurboSI)
website is GMPartsDirect.com
Part #
12223861 for gm 3bar map sensor
Old Aug 27, 2003 | 05:03 PM
thanks a lot. i appreciate it
Old Sep 1, 2003 | 11:02 AM
EG6owner-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9psiTurboSI &raquo;</TD></TR><TR><TD CLASS="quote">if u plan on running more then 11.2psi you need a 3bar map sensor from GM... if you do a search you will find the part number and a website you can purchase it from! i just ordered mine yesterday for my hondata </TD></TR></TABLE>
what happens if you boost more than 11.2 psi on stock map sensor?
Old Sep 1, 2003 | 12:10 PM
alpha's Avatar
Kyle @ KS Motorsports and Vapor (I think) @ Secret Services sells GM 3-bar map sensors too.
Old Sep 1, 2003 | 12:57 PM
tunedbylorange.com's Avatar
you should run the AEM 3.5 Bar looks like this... (on top of manifold)
Old Sep 1, 2003 | 01:13 PM
Joseph Davis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLACKLUDE97 &raquo;</TD></TR><TR><TD CLASS="quote">ok, i have a 00 turbo civic si. i just finished getting sleeves, rods, pistons , and i just got the aem ems. i plan on boosting 22 psi and i hear i need a 3 bar map sensor? i dont know what to do. do i need one? where do i get one?? help me out guys. thanks</TD></TR></TABLE>
Not to be a dick, you need either an education or a reputable shop to help you out. There are a lot of things you are going to need but you won't "hear" about. It's a corollary of Hanlon's Razor.
As far as the OBD1+ Honda MAP sensor reading boost past 10.6 psi, good luck. 11.2 psi, or the 11.3 psi figure Hyundaidata pulled out of their ***, doesn't fly.
ladysman's Avatar
Default Re: 3 bar map sensor?? help!! (tunedbylorange.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tunedbylorange.com &raquo;</TD></TR><TR><TD CLASS="quote">you should run the AEM 3.5 Bar looks like this... (on top of manifold)
Not sure it would work with Hondata though. Anyone tried it?
Old Sep 1, 2003 | 01:32 PM
Default Re: 3 bar map sensor?? help!! (ladysman)
It would alter your pressure column headings somewhat. Nothing ten minutes with a calculator can't deduce.
eg:R
Dec 6, 2008 05:41 PM
beak
Jul 9, 2006 01:28 PM
BoostedJeff
Sep 24, 2004 09:27 AM
1.8turbolsvtec
Apr 14, 2004 04:20 AM
phiberoptik
May 6, 2003 09:43 PM
