Can a Center Section be rotated??
We began to test fit my buddy's SOHC turbo project tonight, and I had to rotate the compressor housing b/c it was hitting the block... Then we bolted it up to the manifold, and i noticed that the drain fitting is pointed sideways...
Can I unbolt the center section and spin it? Do I just undo the bolts and spin it without pulling it all apart or is there something else that i have to do?
It can be rotated, loosen the bolts on both the comrpessor and turbine sides and you'll be able to move it however is convenient.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 25 PSI CRX »</TD></TR><TR><TD CLASS="quote">That manifold looks like obx. </TD></TR></TABLE>
nope... you'll see in a few weeks...
EDIT: And that bracing is added on
g2turbo
Mar 10, 2016 04:24 AM
g2turbo
Jul 9, 2007 09:15 AM
slooogsr
Nov 6, 2003 08:28 PM
