is this the right gm 3 bar map sensor?
Old Aug 30, 2003 | 10:40 PM
crx1856's Avatar
Default is this the right gm 3 bar map sensor?
is this the right gm 3 bar map sensor i need to be able to boost over 10 lbs.
http://www.partsamerica.com/Pa...Set=A
it's off an 1985 regal grand national 6 cyl turbo motor. is it a 3 bar and is it the right one?
Old Aug 30, 2003 | 10:46 PM
MaxSterling's Avatar
Default Re: is this the right gm 3 bar map sensor? (crx1856)
ks-motorsport has 3 bar gm map, http://www.ks-motorsports.com look under hondata-->hondata accessory
Old Aug 30, 2003 | 10:48 PM
crx1856's Avatar
Default Re: is this the right gm 3 bar map sensor? (RoyFokker)
this is only 49 bucks and they have it in stock.
Old Aug 31, 2003 | 01:58 AM
LiLOtaku's Avatar
http://www.gmpartsdirect.com
map sensor part# 16040749 $50.55
Connector part # 15305891 $17.26
These are the usual ones that everyone uses. And your also gonna need the connector as well.
2000FBPITR
Aug 30, 2009 10:19 AM
young geezer
Aug 1, 2009 12:44 PM
b18 hatch mike
Aug 29, 2008 09:33 PM
KRWTEK1
May 28, 2007 12:32 AM
