Neat fuel tank drain plug fact
Old 08-29-2003, 10:53 AM
Bnjmn's Avatar
Default Neat fuel tank drain plug fact
You can get an 1/4" NPT tap, tap the stock drain plug fitting, and insert a 1/4" NPT to -6AN adapter. Piece of cake.
Why is this useful?
Good for ensuring gravity feed for in line fuel pumps. You can have one feed from the stock "bowl" coming out of the top of the tank and another feed from the drain plug fitting. This will ensure that the pump is always primed since it is pretty easy to setup a gravity feed situation using a feed from the drain plug.
Just run a T or a Y into your fuel pump and you are ready to go.
Ben
Old 01-31-2007, 04:40 PM
speedlabx2005's Avatar
Default Re: Neat fuel tank drain plug fact (Bnjmn)
old post but has anyone done this
Tchleung
09-24-2008 01:31 PM
speedlabx2005
01-31-2007 04:38 PM
99teggsr
04-27-2005 06:25 AM
mr. vang
28
04-22-2005 01:25 AM
crxh22project
01-17-2005 11:52 AM
Quick Reply: Neat fuel tank drain plug fact
