oil in inlet manifold ...
Old Aug 27, 2003 | 03:00 AM
Cyber ITR's Avatar
Default oil in inlet manifold ...
i was having this problem, my motor blowing blue smoke at WOT , today i took off my stock gsr inlet manifold , and i found a couple drips of oil inside
where would the oil come from ???
Old Aug 27, 2003 | 03:21 AM
DaveF's Avatar
Default Re: oil in inlet manifold ... (Day Walker)
bad rings.
pcv,
or the valve cover tube that goes into the intake pipe.
Old Aug 27, 2003 | 07:36 AM
GRTechnologies's Avatar
Default Re: oil in inlet manifold ... (2.2Lcivic)
is the car turbo charged? if it is turbos bad. if its not turbo charged could be the pcv
Old Aug 27, 2003 | 09:54 PM
Cyber ITR's Avatar
Default Re: oil in inlet manifold ... (GR)
yeah the car is turbocharged
turbo just rebuilt like 1.5 years ago
i have no idea what could have caused this
compression 200 across, jdm b18c
Old Aug 27, 2003 | 10:00 PM
PrecisionH23a's Avatar
I do not believe in compression tests. However, I do believe in cylinder leakdown tests.
Old Aug 27, 2003 | 10:46 PM
rev-speed's Avatar
i think u should check the turbo
remove the turbo to intercooler hose and inspect 4 oil
b18b12hatch
Jun 2, 2006 08:16 PM
malaya
Feb 25, 2005 06:01 PM
hoggy
Jul 21, 2004 08:06 PM
Ri5e
Jan 17, 2003 02:34 PM
Damon B.
Dec 14, 2002 10:27 AM
