Think I have a vacuum leak?
mine reads about -500 to -550 at idle i believe
how much should it read during boost with a missing link? It should be zero right? mine reads about -45 when my car is boosting. I just replaced some of my vacuum lines, could it be a vacuum leak?
Modified by pip9 at 3:57 PM 8/31/2003
Re: (pip9)
the AFC will be diriving its pressure from input on the map sensor, if it is reading ~50 Mm/hg (Millimeters of mercury) that's pretty close to 0 psi, which i would think is about accurate.
now if that reading decreased while constantly under boost, then your missing link/check valve setup is leaking boost to the map...which it doesen't seem like it's doing.
At idle, depending on your compression it will be ~400 - ~600 Mm/hg.
If you still suspect you have a vacuum leak and you REALLY want to make sure, you can build a presure testing device, and pressurise the whole intake system and listen for air leaks.
lazerus... Before i put in my new motor it always read 0 when i was at boost. I'm not exactly sure but i think it was 0 after i installed my motor but I just notice the new prs reading after installing the new vacuum lines. It seems to run fine other than that. I have one other question though the thrt volt reading under sensor reads .48-.49 I was reading on the hondata site that the tps should be .45v exactly. Is that reading for the tps? If so is that hurting my engine at all?
Re: (pip9)
i figured out why my prs setting wasn't reading zero. I was up in western md this whole weekend and the altitude effected the pressure reading on the afc. As i was coming back home the prs setting got closer and closer to zero. And now its back to normal.
Re: (Happyman)
it takes line 5min and $5 to make a leak tester...just go to home depot/lowes and get a pvc pipe cap in whatever size your i/c pipe is, then get a brass nipple with threads on the other size.....drill a hole in the end of the cap and screw the nipple in then put some jbweld around it to ensure it doesnt leak...then take an i/c pipe off the tighten down the pvc to the other side of the rubber coupling.... then hook a rubber line from the nipple to the end of a blower attactment on an air compressor...blow the air in and watch your boost guage and stop when its at whatever boost you want and listen for leaks.
Baggy Spandex
04-02-2006 07:50 AM
