help on piston size and dart block
Old Feb 26, 2004 | 08:12 PM
turboex's Avatar
Default help on piston size and dart block
Ok the dart block I have is 84.5mm bore. So do i need 84.5mm pistons? Reason i ask is stock b20's are 84mm so why does dart only offer it in 84.5mm? thanks
Old Feb 26, 2004 | 08:31 PM
turboex's Avatar
Default Re: help on piston size and dart block (turboex)
also does anyone know a general piston to wall clearance? thanks
Old Feb 26, 2004 | 08:43 PM
hotasscivic's Avatar
yes you need 84.5mm pistons and piston to wall clearances differ per each set up
Old Mar 1, 2004 | 11:11 AM
Moxie's Avatar
Default Re: help on piston size and dart block (hotasscivic)
JE, Wiseco, and a few other piston manufacturers manufacture pistons for this application. Contact them and they can set you up with the right parts.
Ryhaz
10
Jan 14, 2014 07:57 AM
f22 killer
Sep 24, 2011 03:23 PM
hYbRid_Eg6
Mar 16, 2010 07:40 AM
B pwr
Mar 26, 2003 10:44 AM
speedy108
Nov 25, 2002 07:24 PM
