? for Turbo/Nitrous users!
Old Feb 28, 2004 | 09:12 AM
NirVTEC's Avatar
Default ? for Turbo/Nitrous users!
Do you use a wet or Direct port setup? I am building a turbo motor with a fairly large snail and figure a nice sweet 50 shot should do the trick to reduce that lag. I currently run a wet setup and want to figure out if I should start collecting DP parts.
Old Feb 28, 2004 | 01:58 PM
J337_UNIT's Avatar
Default Re: ? for Turbo/Nitrous users! (NirVTECn2o)
its not a good idea to spray nitrous at low rpms...
Old Mar 1, 2004 | 10:48 AM
NirVTEC's Avatar
Default Re: ? for Turbo/Nitrous users! (J337_UNIT)
OK....so do I use wet or DP?
Old Mar 1, 2004 | 01:50 PM
tegasaurus's Avatar
im pretty sure the least you can run on a direct port is an 80 shot. IF you're only going to be juicing from like 3-5.5k, then a wet kit will do just fine
Old Mar 1, 2004 | 03:32 PM
NirVTEC's Avatar
Sweet! I was planning to buy the 50 shot jets anyway for roadracing with nitrous! I will just use a wet setup then....
Old Mar 1, 2004 | 03:33 PM
SOHCArchangel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NirVTECn2o &raquo;</TD></TR><TR><TD CLASS="quote">OK....so do I use wet or DP?
shameless plug:
i have a single fogger wet kit for sale on e-ghey
https://honda-tech.com/zerothread?id=782732
karmadhi
Mar 12, 2014 08:23 PM
Doug684
Jan 4, 2004 02:51 PM
Lewie
Feb 6, 2003 06:11 AM
Boostless97Lude
Dec 19, 2002 12:49 PM
vspec12
Nov 15, 2001 03:16 PM
