check engine light
Old Feb 29, 2004 | 01:25 PM
jamesr's Avatar
Default check engine light
ohk got the greddy kit installed on my d16y8 this past weekend, runs strong non-intercooled. check engine light throws around 6-7 rpms, the code is p108. any suggestions?
Old Feb 29, 2004 | 02:55 PM
Chiovnidca's Avatar
Default Re: check engine light (jamesr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jamesr &raquo;</TD></TR><TR><TD CLASS="quote">ohk got the greddy kit installed on my d16y8 this past weekend, runs strong non-intercooled. check engine light throws around 6-7 rpms, the code is p108. any suggestions?</TD></TR></TABLE>
Do you mean p0108? That would be a MAP code. Does the d16y8 kit come with a FMU? Is it wired up properly?
Old Feb 29, 2004 | 03:06 PM
jamesr's Avatar
it is the p0108 code. im running the blue box. i am certian that it is properly wired.
Old Feb 29, 2004 | 03:18 PM
Chiovnidca's Avatar
Default Re: (jamesr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jamesr &raquo;</TD></TR><TR><TD CLASS="quote">it is the p0108 code. im running the blue box. i am certian that it is properly wired.</TD></TR></TABLE>
The blue box fmu is supposed to show the ECU a good MAP voltage so it wont code.
Old Feb 29, 2004 | 03:40 PM
streetlvlhatch's Avatar
Default Re: (Chiovnidca)
hey i know exactly what your talking about. My friends greddy turboed civic does the same thing, only he has emanage. The check engine light goes off when he holds boost for too long, and the map code goes off. I think this is a problem that greddy should deal with. I think it is a glitch in their program.
Old Feb 29, 2004 | 04:23 PM
IZsd's Avatar
Default Re: (streetlvlhatch)
Just wanted to add, that with a scan tool attached. The map pid appears to be acting almost as if its seeing boost.
Does anyone know what the altered value from the map after the Emange is/or should be????
His car is using Emanage, everything is soldered/shrinked
Later IZ
Old Feb 29, 2004 | 04:28 PM
Default Re: (IZsd)
3.1 v is the cutoff on the emanage i believe. and yes all is soldered.
seanewing
Apr 29, 2010 12:18 PM
BolivianDc2
Feb 14, 2005 07:55 AM
surfingsk8r
Jan 27, 2005 06:24 AM
afterburners
Feb 2, 2004 05:18 AM
jdm civic
Jun 4, 2002 05:04 AM
