1st gen Eclipse BOV ???
Old Mar 1, 2004 | 07:55 PM
ONEdotEIGHt-T's Avatar
Default 1st gen Eclipse BOV ???
Does anyone use this BOV? or know anything about it when using it with a B16 running 6-7 pounds?
-john
Old Mar 1, 2004 | 08:17 PM
falcongsr's Avatar
What is this crap?
Default Re: 1st gen Eclipse BOV ??? (ONEdotEIGHt-T)
i know it should work fine...
Old Mar 2, 2004 | 10:46 AM
dunkd's Avatar
if you want the ill "whoosh" get a more expensive one... turbo xs rfl, greddy, hks...
Old Mar 2, 2004 | 11:09 AM
racinskittle's Avatar
Default Re: (dunkd)
it works fine. I run it. It also makes a "whooosh" it just doesn't make the bird chirp noise like the rest
Old Mar 2, 2004 | 03:03 PM
falcongsr's Avatar
What is this crap?
Default Re: (racinskittle)
additional sounds like bird chirping = ineffeciency in releasing boost pressure.
Old Mar 2, 2004 | 03:57 PM
blown_LS's Avatar
Default Re: (falconGSR)
i'll work just fine. Just crush it and it will sound little bit better. I had it on my teg and now... well it came stock with my car.
Old Mar 2, 2004 | 05:01 PM
Adriano's Avatar
Default Re: (blown_LS)
A stock 1G bov will hold 18-19lbs with no problem. You can "crush" i to hold more boost.
Old Mar 2, 2004 | 05:14 PM
liveforphysics's Avatar
they work great. Also, if you turn it upsidedown there is a small indent you can drill down into. This connects it to the back side of the diaphram so it be made to open with boost and/or vaccum.
The crush mod will just put a little more spring pressure on the diaphram. This means it will hold a few more psi. No need for your low boost application.
Old Mar 2, 2004 | 05:31 PM
Default Re: (liveforphysics)
Thanks for the info everyone.
asubennett
Nov 14, 2005 01:16 AM
Jayboy
May 12, 2005 10:57 PM
XxRoCkMaNxNEOxX
Nov 5, 2004 07:30 PM
oemDC2
Feb 26, 2004 08:03 PM
JustAnotherHonda
Feb 13, 2003 05:39 AM
