***important*** sAFC + Rc 310 injector question
* B A N N E D *
one if on the fuel setting on a safc is set on -50% on a 440 injector = 220 which is almost stock flow
now the real question...
im planning to use 310 injectors instead.. what is the most -x amount can i subtract to get closest to stock?i figured -25% is still not close enought to stock injector flow
can some1 give me an almost exact number to get as close to stock as possible thanks in advance.. also can you also tell me how you guys figured out the actual number.. post an example thanks again
Re: ***important*** sAFC + Rc 310 injector question (ShowTymers619)
310 x .78 = 241. So about 22% subtracted should be close to the stock 240cc.
Thats the math I came up with.
* B A N N E D *
Re: ***important*** sAFC + Rc 310 injector question (Civic_95_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic_95_Si »</TD></TR><TR><TD CLASS="quote">310 x .78 = 241. So about 22% subtracted should be close to the stock 240cc.
Thats the math I came up with. </TD></TR></TABLE>
ok thanks..
ok thanks..
dem0nk1d
02-04-2007 11:25 AM
