Low compression motor drivability
Old Feb 29, 2004 | 03:47 PM
streetlvlhatch's Avatar
Default Low compression motor drivability
I just recently finished my ls/vtec build, and have been working out the problems. My motor sounds like a school bus/ disel at idle for some reason. I checked the exhaust side clearance and it was all in spec, but i didnt check the intake valves b/c i didnt have a .007 feeler gauge. The ticking kind of a sound is coming from the valvetrain. what could this be?
Next, i was wondering how my motor should feel compared to my dx. I have a ls block with ls 8.5:1 compression with a gsr head. This should bring it to around 9 right? It doesnt feel all that more powerful than the dx. Is this normal?
Old Feb 29, 2004 | 04:06 PM
markaria's Avatar
Default Re: Low compression motor drivability (streetlvlhatch)
what ecu are you using? If its the stock one from the dx, then it probably wont be faster. Definitely check the intake side as well. Oh, the dohc honda motors do have a different sound than the sohc, but it shouldn't sound like a diesel either.
Old Feb 29, 2004 | 04:29 PM
Default Re: Low compression motor drivability (markaria)
im using p72
Old Feb 29, 2004 | 04:36 PM
tegasaurus's Avatar
nevermind what the compression ratio is, get some compression numbers and do a leak down test.
Old Feb 29, 2004 | 04:43 PM
Default Re: Low compression motor drivability (tegasaurus)
when i had 20 miles on it, and i did a oil change, i had 190, 185, 187, 183. No leakdown because i dont have air.
Old Feb 29, 2004 | 05:08 PM
Adam F's Avatar
I had a destrocked gsr block that was 9.2 to 1 and it drove decent on the street with no turbo. I couldn't beat many people, but it wasn't as slow as my d-series. It also sounded like a diesel. When I took it apart, i found out why. I had about 10 valves that weren't seated. HtH
Old Feb 29, 2004 | 05:12 PM
Teg4e's Avatar
Default Re: Low compression motor drivability (Adam F)
after over revving my LS, my engine sounded like a diesel, but drove normal. The vash lash nuts had come off a bunch of the valves and they were out of whack. I got a valve adjustment done and it's been fine since.
Old Feb 29, 2004 | 06:31 PM
snoochtodanooch's Avatar
Default Re: Low compression motor drivability (Teg4e)
yea i have seen many a honda passport with this same valvetrain problem. Just needs a little shimming and adjusting most likely. sounds like a tick tick tick tick that follows with engine rpm. Hope the repair works.
Old Feb 29, 2004 | 06:34 PM
DaX's Avatar
DaX
Loved
Community Favorite
I adjust valves twice a year. Last month I found almost all my intake valves to be .002 larger gap than called for! Tightening up the lash made the valve train much quieter.
Old Feb 29, 2004 | 06:35 PM
soundman's Avatar
If u listen to a DSM engine it's common... I had an eclipse that ticked like crazy... They had the hydrolic adjusters in them though, and you couldnt adjust it...
Old Feb 29, 2004 | 06:39 PM
99B16Si's Avatar
if your have forged pistons and the piston to wall clearance is too loose it will sound like a diesle especially when cold
xxliljonxx1
11
Jun 4, 2012 01:47 PM
H22HondaCRX
Mar 19, 2007 10:09 PM
300guy
Jun 28, 2005 10:57 AM
