Oil Return Line
Old Mar 1, 2004 | 03:56 PM
mike34655's Avatar
Default Oil Return Line
I just recently purchased an oil return line from flamenco-T but I dont know how to assemble it. I tried to get the red things on the line but it just wont fit. Is there a trick to it or am I just not man enough to get it on? Thanks for any advice.
Old Mar 1, 2004 | 04:36 PM
IN VTEC's Avatar
Default Re: Oil Return Line (mike34655)
Don't let the ends fray. Keep some of the tape around the end to assist you in inserting it into the hose-end then pull off the tape. If it frayed, then you'll have to recut the end.
-10AN is a lot easier to work with than smaller lines b/c the rubber can flex.
Old Mar 1, 2004 | 04:39 PM
DaX's Avatar
DaX
Loved
Community Favorite
http://www.fast-turbo.com/anlines.html
Old Mar 1, 2004 | 05:26 PM
delslowh23's Avatar
Default Re: (DaX)
lube it
Old Mar 1, 2004 | 06:47 PM
mike34655's Avatar
Thanks for the replys. I finally got it together.
PinoyDelS0l
Aug 30, 2009 12:43 AM
saikouEF8
Dec 2, 2008 03:50 PM
Sketch_hs
Jun 23, 2005 02:11 PM
sohc_vtec 2NR
May 6, 2004 10:32 AM
PrecisionH23a
Jun 16, 2002 07:53 PM
