Bogging?
Old Mar 1, 2004 | 02:22 PM
egizzle8
Guest
Posts: n/a
Default Bogging?
Well I finally installed my home made kit and it spools up fine and then starts bogging at about 6-7k. While I was tightening the manifold the actuator got kinda dented by the front driver side mount on my y7. Could this be the problem? Its's a pretty simple setup with a wrx turbo and hf mani and dsm smic. I haven't put on my vortech 12:1 fmu. Any ideas? I know it's kinda broad but anything would help.
Old Mar 1, 2004 | 02:25 PM
Turbo E's Avatar
plug gap too big? running too righ? any smoke?
Old Mar 1, 2004 | 02:27 PM
Mase's Avatar
Default Re: (Turbo E 604)
wtf, you havent added any fuel management and your trying to boost?
Say bye bye to that motor if you keep it up.
Old Mar 1, 2004 | 02:28 PM
TravSi's Avatar
Default Re: Bogging? (egizzle6)
well if you didnt get yur fmu hooked up what is supplying your fuel in boost? There could lye the problem
Old Mar 1, 2004 | 02:42 PM
egizzle8
Guest
Posts: n/a
Default Re: (Mase)
No smoke no nothing. Yeah yeah I know about the goodbye engine. Being that the actuator is kinda crushed wouldn't that also stop it from building boost?
Old Mar 1, 2004 | 02:45 PM
Turbo E's Avatar
got a fuel pump yet?
Old Mar 1, 2004 | 02:51 PM
egizzle8
Guest
Posts: n/a
Default Re: (egizzle6)
Got one just have to install it. It's an airtronix. My own procrastination with be my engine's demise! So the dented in actuator wouldn't cause anything. I can barely open the wastegate after it happened.
Old Mar 1, 2004 | 03:38 PM
Turbo E's Avatar
got a pic? how bad is the dent?
Old Mar 3, 2004 | 03:23 PM
egizzle8
Guest
Posts: n/a
Well I installed my vortech fmu and she's running like a top! This the fuel pump will go in for some back up. Also I don't feel like running the dsm 450 and running a resistor box. Are there any other stock honda injectors that don't require the resistor box and more than stock 240 injectors? Maybe Prelude' h22's?
Go Fast Civic
Dec 1, 2004 01:09 PM
SOHC_power
Oct 30, 2002 03:43 AM
HondaCutter
Sep 25, 2002 08:59 PM
jmad08
Jul 30, 2002 10:02 AM
