catch can for d series
Old Mar 1, 2004 | 08:08 PM
turbo sol's Avatar
Default catch can for d series
I see alot of info about running one for a b series, but anyone have a nice easy setup for a d series with some pics?
Old Mar 1, 2004 | 08:16 PM
showtymers619's Avatar
* B A N N E D *
Default Re: catch can for d series (turbo sol)
just hook it up to the pcv valve and put the tank inline of it
Old Mar 1, 2004 | 08:23 PM
5thgencivic's Avatar
Default Re: catch can for d series (ShowTymers619)
I'll snap a pic of mine tomorrow. One line goes from the valve cover to a nipple on the catch, another from the black box on the back of the block to the other nipple. A breather filter on top of the catch vents it.
Old Mar 2, 2004 | 10:49 AM
Default Re: catch can for d series (5thgencivic)
I got rid of the PCV a long time ago
Old Mar 2, 2004 | 11:04 AM
psileepR's Avatar
New User
bump for any more d series catch can pictures.
Old Mar 2, 2004 | 09:07 PM
turbo sol's Avatar
Default Re: catch can for d series (psileepR)
so you guys dont worry about tying it in to the charge pipe? the setup above looks simple enough.
Old Mar 2, 2004 | 09:25 PM
Cruiser G's Avatar
I thought for a catch can to work right you need some kind of vacuum source. So this isn't true?
Old Mar 2, 2004 | 09:49 PM
Default Re: catch can for d series (Cruiser G)
On a boosted car from what I've read and experienced vacuum isn't a requirement. At idle I can see vapors exiting and under boost on the dyno I could see the vapor clouds "blowing" out. Vacuum might help, but it's something I don't think I need..
Old Mar 3, 2004 | 08:59 AM
turbo sol's Avatar
what did you do with the hole the other end of the PVC valve went to?
Old Mar 3, 2004 | 10:14 AM
I left the hose on the intake manifold and just plugged the end with a bolt
Old Mar 3, 2004 | 10:48 AM
lucrative's Avatar
Why is there a "breather filter" on the catch can? Don't you just connect the valve cover opening to the catch can and then from the catch can to the intake piping connected between the Air Filter and the turbo? What use does the breather filter have... ?
Old Mar 3, 2004 | 11:27 AM
DaX's Avatar
DaX
Loved
Community Favorite
It dissipates the vapors so you don't have to empty your can as often.
Old Apr 12, 2004 | 07:46 AM
GPNY's Avatar
This is good info.
Quick question though:
Can I run a tee on the line coming out of the black can (oil separator) and let the oil drain back into the motor from the bottom of the catch can (just like endyn's kit) or are there other things I need to do beforehand?
This would avoid needing to empty the can all the time...
Old Apr 12, 2004 | 07:56 AM
VNTEC's Avatar
B A N N E D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgencivic &raquo;</TD></TR><TR><TD CLASS="quote">I got rid of the PCV a long time ago
Wait a minute, so your using the valve cover nipple to act like a vacuum source when ur on the throttle? Thats the only reason why that line would be there now wouldnt it? Or am i missing something
Freshdot
Jul 7, 2010 04:21 PM
Turbochargedcivic
Aug 12, 2006 02:56 PM
4door93civic
18
Nov 30, 2003 08:05 AM
Dragger817
Audio / Security / Video
Aug 21, 2002 08:22 AM
