??? on full-race a/c manifold
Old Feb 27, 2004 | 04:06 PM
yellowmonkeyboy's Avatar
Default ??? on full-race a/c manifold
hey guys
im trying to decide on what manifold to purchase, the thing is i want to retain my a/c. i have a 2000 GSR coupe and will be using a straight t4 turbo and a 3" dp... i was jus wondering if the full-race a/c manifold would allow me to use a 3" dp...
will there be enough room for the 3" dp without getting in the way of the a/c unit?
thanx for your help
Old Feb 27, 2004 | 04:27 PM
Mase's Avatar
Default Re: ??? on full-race a/c manifold (yellowmonkeyboy)
3" will work
Old Feb 27, 2004 | 06:19 PM
c jackson's Avatar
threes
Default Re: ??? on full-race a/c manifold (Mase)
yep, but with the t4 flange its a tight fit.
Old Feb 27, 2004 | 07:22 PM
Full-Race Geoff's Avatar
It is very do-able but the use of a t4 will require that whoever does the install needs to be a competent mechanic.
Old Feb 27, 2004 | 08:14 PM
buck02's Avatar
Default Re: ??? on full-race a/c manifold (Full-Race Geoff)
well i hope mine goes well i got the exact set your looking for and i hope mine goes in well
Old Feb 27, 2004 | 09:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full-Race Geoff &raquo;</TD></TR><TR><TD CLASS="quote">It is very do-able but the use of a t4 will require that whoever does the install needs to be a competent mechanic.</TD></TR></TABLE>
what do you exactly mean by competent???? is there anything special that you have to do as in cutting?... jus wondering b/c me and my friends plan on doing the install ourselves (dont have money to get it installed, costs too much), we have done a motor swap and regular exhausts, suspension, headgaskets and stuff.. so would that mean we would be competent enough to do it... haha
thanx for your info and help
Old Feb 27, 2004 | 09:24 PM
its a tough install. you need good tools, and you need to understand how a turbo works. if youre trying to put a t4 in a car and its your first turbo install you will probably have a really hard time doing it
i strongly reocmmend losing the AC. it makes the car soooooooooooo mcuh easier to work on.
Old Feb 27, 2004 | 09:34 PM
Nid Styles's Avatar
Sounds to me, that you don't want to weld up another A/C unit.
Modified by nd_styles at 3:27 AM 2/28/2004
Old Feb 27, 2004 | 09:57 PM
Default Re: ??? on full-race a/c manifold (nd_styles)
ok thanx for your help... but basically it will fit with the a/c unit still in place. will there be any heating issues of the downpipe being too close to the a/c unit that it will melt the belt on the a/c unit?... also how much clearance would there be between the a/c unit and the dp
Old Feb 27, 2004 | 10:11 PM
Naterror's Avatar
I have the same question, but with a t3/60-1. Losing a/c is not a choice, down here it gets pretty hot in the summer with high humidity.
Do you all (full-race) make a a/c manifold kit for a EK chasis or just the manifold?
Old Feb 28, 2004 | 08:19 AM
Default Re: ??? on full-race a/c manifold (Naterror)
we dont mind welding them, you juyst have to be prepared for the install
we do make a complete kit for a B series with AC in an EK chassis. Check out our Si on the site
as far as the DP being too close to the compressor -- we havent had any problems yet in arizona (pretty hot) but who knows what will happen over time. There is about 1/2" clearance
Old Feb 28, 2004 | 09:44 AM
Naterror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full-Race Geoff &raquo;</TD></TR><TR><TD CLASS="quote">we do make a complete kit for a B series with AC in an EK chassis. Check out our Si on the site
Thats the only link that doesn't work for me
Old Feb 28, 2004 | 02:39 PM
i hope this helps
Old Feb 28, 2004 | 09:28 PM
thanx alot for your help and info... i hope to be talking to you guys soon to purchase a manifold and dp...
Old Feb 29, 2004 | 07:50 PM
Naterror's Avatar
i hope this helps</TD></TR></TABLE>
what did ya'll do for an intake filter?
supracharger
Oct 6, 2008 05:05 PM
ampere
May 16, 2008 09:59 PM
LSTEG98
Jan 10, 2007 08:03 PM
ATL-Honda-Tuner
Jun 18, 2005 02:15 AM
*Boostwerks*
Dec 28, 2003 09:04 PM
