Oil feed and return lines
Old Mar 1, 2004 | 08:41 PM
beepy's Avatar
Default Oil feed and return lines
Would I face any possible complications if the drain line to my oil pan is the same ID as the feed line from the block?
Because of close proximity to my manifold, I am worried about the socketless -AN line failing and want to replace it with hard line, but the hard line that has the same size connectors as my socketless hose is 1/4" IF, the same as the feed line.
Old Mar 1, 2004 | 09:26 PM
PrecisionH23a's Avatar
Default Re: Oil feed and return lines (beepy)
Yes. You will blow your oil seals out.
You must use at least a 5/8" return line.
PinoyDelS0l
Aug 30, 2009 12:43 AM
B18 CYA
Apr 21, 2004 04:34 PM
lilxvtecxpwr
Oct 5, 2002 03:35 PM
Damon B.
Jan 30, 2002 12:32 AM
