can a 84.5mm headgasket be used on a 84mm bore?
Just as i ask, need to know if ill have an problems running a 84.5mm hg on a 84mm bore Reason i ask is cause i hear hoda stock head gaskets are a tad over sized. thanks
Re: can a 84.5mm headgasket be used on a 84mm bore? (PureTeg420)
why the coper spray if its a stock gasket? its honda part just bored by GE. thanks for you imput
I've quit using this account
Re: can a 84.5mm headgasket be used on a 84mm bore? (turboex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboex »</TD></TR><TR><TD CLASS="quote">Ah, would it be better to just get the right gasket?
what kinda question is that?
of course it would be better to get the right HG. if you arent gonna do that, then use copperspray.
Re: can a 84.5mm headgasket be used on a 84mm bore? (llewsirc)
you could use that headgasket but if you do research on copper spray it does not dry with the heat and creates head movement, even with the dowel pins.
Re: (LudeyKrus)
Did not need the hating but hey what can you do.. The reason i asked this is cause i have read before that stock honda head gaskets are over sized. I was wondering buy how much so that i could work something out. But hey ill just order another gasket. thanks for the help.
Call Vince tomorrow afternoon and talk with him. He is a nice guy. I'm willing to bet he will exchange it for you. You are resleeved so I say get the 84mm head gasket.
hondaapi
10-20-2004 09:42 PM
