Best Plug for 550+
Old Mar 1, 2004 | 09:35 AM
hybrid901's Avatar
Default Best Plug for 550+
What is the best NGK plug for over 550whp? I was running a 9 heat range plug last year but forgot the part number.
Old Mar 1, 2004 | 11:08 AM
ladysman's Avatar
Default Re: Best Plug for 550+ (hybrid901)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid901 &raquo;</TD></TR><TR><TD CLASS="quote">What is the best NGK plug for over 550whp? I was running a 9 heat range plug last year but forgot the part number.</TD></TR></TABLE>
See my thread and the second post under this thread. That should help.
https://honda-tech.com/zero...age=1
This also may help?
Old Mar 1, 2004 | 11:28 AM
b18bturbo's Avatar
i would use the rg5671-a number 8
Old Mar 1, 2004 | 11:30 AM
DaX's Avatar
DaX
Loved
Community Favorite
b18bturbo....would you recommend that also for someone going turbo but boosting lower numbers and making less horsepower, or will I be fine with stock NGK's?
//end thread hijack
Old Mar 1, 2004 | 11:31 AM
hybrid901's Avatar
Default Re: Best Plug for 550+ (b18bturbo)
Are the 8's cold enough or would I need 9's.
b18bturbo's Avatar
Default Re: (DaX)
for low hp the bcpr7es11 is most common plug
the 5671-a plugs are usually good for racing only not really used on street that often. mostly a race type plug. i used to run the 9s 10s and 11s
Old Mar 1, 2004 | 11:33 AM
b18bturbo's Avatar
Default Re: (b18bturbo)
i would start with a 8 and work your way down. but 8 should be plenty for your setup.
Old Mar 1, 2004 | 11:35 AM
DaX's Avatar
DaX
Loved
Community Favorite
Will any auto part store have them? Can I just take that part number [bcpr7es11] and get them?
Mase's Avatar
Id run the 9's
Old Mar 1, 2004 | 11:37 AM
b18bturbo's Avatar
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">Will any auto part store have them? Can I just take that part number [bcpr7es11] and get them?</TD></TR></TABLE>
part number from NGK is 1095 ask for that at napa or any local parts store
Old Mar 1, 2004 | 11:45 AM
Scott - 93HB Si's Avatar
BKR7E's line up with 5672A's in that chart...why would you goto a 5671 (non-projected tip)???
Old Mar 1, 2004 | 12:59 PM
92HB_HB's Avatar
Default Re: (Scott - 93HB Si)
i'm assuming i would need the 8's then.. i'm curently running bcpr7es's and i am misfireing/stumbling badly up top at 75%-100% throttle, this was only at about 10 psi on my stock gsr.. they were gapped at .030 as well.. when i regapped them to about .020, my full throttle was smooth, but idle sucked real bad..
bump..
Old Mar 1, 2004 | 01:10 PM
DIRep972's Avatar
Smarter than you
Default Re: (92HB_HB)
you should not be having a problem w/ the 7's @ .030 on a stock GSR. There is something else wrong w/ ur set up then.
Old Mar 1, 2004 | 01:12 PM
TurboTegB18c's Avatar
Default Re: (DIRep972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">you should not be having a problem w/ the 7's @ .030 on a stock GSR. There is something else wrong w/ ur set up then.
On the real, i was running the 7's and made 450whp.
Old Mar 1, 2004 | 01:13 PM
ngk R5671a-8 part# is 4554
ngk R5671a-9 part# is 5238
Old Mar 1, 2004 | 02:30 PM
hybrid901's Avatar
Default Re: Best Plug for 550+ (TurboTegB18c)
Those happen to be the 2 different plugs I ordered earlier, 8 of each.
Old Mar 1, 2004 | 02:53 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid901 &raquo;</TD></TR><TR><TD CLASS="quote">ngk R5671a-8 part# is 4554
Those happen to be the 2 different plugs I ordered earlier, 8 of each.</TD></TR></TABLE>
Keep us posted cause I am curious. My thought was 9's but 8's might be OK.
Good luck.
Old Mar 1, 2004 | 03:10 PM
gitwidit's Avatar
Default Re: Best Plug for 550+ (ladysman)
R5671A-9 for anything over 500whp
Old Mar 1, 2004 | 04:21 PM
DaX's Avatar
DaX
Loved
Community Favorite
Higher or lower number with more horsepower?
Old Mar 1, 2004 | 04:22 PM
ladysman's Avatar
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">Higher or lower number with more horsepower?</TD></TR></TABLE>
Higher. The higher the number the colder the plug.
Old Mar 1, 2004 | 04:27 PM
DaX's Avatar
DaX
Loved
Community Favorite
so what cold range number are the bcpr7es11 / PN 1095?
81CB900C
Aug 16, 2007 09:07 AM
garyc17
May 11, 2007 09:51 AM
BodyKits NW
Feb 19, 2004 01:57 PM
Shft@9GSR
Oct 16, 2003 12:04 PM
TeamTooQuick
Aug 9, 2003 07:23 PM
