Small Turbo Problem
Old Feb 27, 2004 | 07:13 PM
frago's Avatar
Default Small Turbo Problem
I have a T-28 turbo on a SOHC Civic. I am going to the track tomorrow... and tonight did a little maintenance to my vehicle. I took off the intake pipe and the pipe after the turbo before the intercooler just to look. This is what I found...
Intake pipe had a little water/dirt in it but nothing out of the ordinary.
Pipe after turbo before intercooler, I found a tiny bit of oil.
I then felt the turbo for shaft play and it had a little tiny bit.
My questions are...
What does this exactly mean?
How do I fix it?
Is there a way to adjust the turbo so it eliminates the little bit of shaft play?
Thanks for your time in advance.
Old Feb 27, 2004 | 07:43 PM
frago's Avatar
Default Re: Small Turbo Problem (frago)
BUMP
Anyone Please... I am a little worried!
Thanks again.
Old Feb 27, 2004 | 08:47 PM
MiraiZ's Avatar
is this turbo new? Does it smoke?
Old Feb 27, 2004 | 11:43 PM
Johnyquest's Avatar
Default Re: Small Turbo Problem (MiraiZ)
shaft play is normal--- chill b
Go to the track and have a good time. Turbo bearings FLOAT on oil.
Old Feb 27, 2004 | 11:49 PM
Nid Styles's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ &raquo;</TD></TR><TR><TD CLASS="quote">is this turbo new? Does it smoke?</TD></TR></TABLE>
Oil shouldn't be in his charge piping, or the intercooler. If it smokes you have a bad turbo seal. Beside even new turbo seals can go if his BOV isn't working properly.
Old Feb 28, 2004 | 12:04 AM
FredoSP's Avatar
Default Re: Small Turbo Problem (nd_styles)
PLEASE check ur compression, sounds like one cylinders ringlands might be giving way.
Here's what happened to me ..
my compression was 180 90 190 210; (3rd cylinder ringlands were cracked), hence blow by of oil into the pipes etc.
I noticed this after a weird idle and the car felt funny. A compression test takes 10 minutes and u can buy the gauge at Autozone / Pep boys for like 10-15 bucks!
Old Feb 28, 2004 | 12:26 AM
Nid Styles's Avatar
Default Re: Small Turbo Problem (FredoSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP &raquo;</TD></TR><TR><TD CLASS="quote">PLEASE check ur compression, sounds like one cylinders ringlands might be giving way.
I noticed this after a weird idle and the car felt funny. A compression test takes 10 minutes and u can buy the gauge at Autozone / Pep boys for like 10-15 bucks!</TD></TR></TABLE>
What you're decribing wouldn't cause oil in the intake.
Just out of curiousity what management are you using?
Old Feb 28, 2004 | 05:30 PM
frago's Avatar
I am using Link engine managment.
The car is not smoking at all yet.
I ran a 13.62 @ 105mph w/o my slicks or my LSD tranny.
My pistons and rings are brand new no leak, but I will check anyways to see what it says.
My BOV sucks big time, I can hear it go back into the turbo before it completely opens. I hate it.
How would I replace the seals? Is it hard?
Old Feb 28, 2004 | 08:26 PM
ion_four's Avatar
These were too unrelated symptoms...oil does not go backwards from the engine, through the intake manifold and pipes...
There is no way to fix a turbo seal without rebuilding it. Unless it is REALLY horrible, there's nothing to worry about, aside from blowing some smoke and using a little oil. If the play is really bad, more than ~3-4mm there's a chance your turbine or compressor wheel will hit the housing, but this is unlikely.
Old Feb 29, 2004 | 03:35 PM
frago's Avatar
Ok, thanks for all of your help!
You can check it out at http://www.cardomain.com/id/rexinre
Thanks again
Old Mar 1, 2004 | 09:14 PM
FredoSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nd_styles &raquo;</TD></TR><TR><TD CLASS="quote">
Just out of curiousity what management are you using?</TD></TR></TABLE>
Again from the org. poster
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frago &raquo;</TD></TR><TR><TD CLASS="quote">
Pipe after turbo before intercooler, I found a tiny bit of oil. </TD></TR></TABLE>
Maybe I should make it clear what I was trying to state. Since the Greddy Kit (the one I had) relocates the stock PCV hose to the intake piping. Now, if someone has an abnormal about of blow-by due to cracked ringlands, this will cause a lot (more than usual) of oil + vapors to by displaced into the intake piping of the turbo and into the piping - pre-intercooler.
In any event, this was my situation. Its always best to do a compression test and leak down to rule out the obvious and then start to look at other things.
Old Mar 2, 2004 | 07:08 AM
frago's Avatar
Good point ^^^ However, I don't have the PVC pipe going to the intake. I just plugged the hole and put a breather on the Valve Cover. That is a good thought though I would have never thought of that.
Thanks again.
Check out my site and you can see other things I have done to her! http://www.cardomain.com/id/rexinre
hatchinprogress
Oct 31, 2005 06:15 PM
PreludeSiTdriver
Dec 9, 2004 01:05 PM
h22vtecmonster
Nov 8, 2004 11:37 AM
SIK IN DA HED
Feb 11, 2004 11:58 PM
