My turbo setup!
Old Feb 29, 2004 | 02:04 PM
vteckiller's Avatar
Default My turbo setup!
I am about to boost my type r(b18c5) and this is what i Have planned to be
installed. will be run on stock bottom end. have all gauges,tt, greddy profec b spec2
inline pro log mani
sc34 precision turbo
custom 2.5 in dp
inline pro intercooler piping
tial 38mm wastegate
hks ssq bov
precision 31.5x8.0x3.5 fmic
rc 550cc sat inj w obd2 clips
walboro 255lph in tank fuel pump
cometic headgasket
str block guard
hondata s200b p28 ecu
cm stage 4
I am shooting to run around 12psi daily and 15 at track. how much hp do you think i will net with this setup. Thanx in advance
Old Feb 29, 2004 | 03:28 PM
b16ahybrid's Avatar
Default Re: My turbo setup! (vteckiller)
Thats a lot of boost for a stock type r.
Good luck,
Old Feb 29, 2004 | 04:12 PM
mrDFWmechanic's Avatar
id suggest doing whatever you can to lower the compression ... to play it safe. thats a lot of boost bro ... dont blow the ****
Old Feb 29, 2004 | 04:26 PM
brickonwheels's Avatar
I agree with civryder02, that is a pretty high compression motor but good luck
Old Feb 29, 2004 | 05:21 PM
Chillinit's Avatar
Default Re: (brickonwheels)
8 psi on a type-r is plenty...never mind 12!!!...I would even do 6psi if ur sticking with stock internal and stock compression...goodluck
Old Feb 29, 2004 | 05:23 PM
99B16Si's Avatar
sell your complete c5 bottom and build a gsr block. youll practically make money
Old Feb 29, 2004 | 05:33 PM
johncarlos's Avatar
why boost a type-r?
you going to limit the amount of power you can make because if the compression ratio.
and if you do lower the ratio you just defeat the reason you have a type-r just my.02
Old Feb 29, 2004 | 05:46 PM
B17aTrbo's Avatar
New User
Default Re: (turbokitssuck)
IMO type-r is for doing an all motor setup...
Old Feb 29, 2004 | 05:53 PM
johncarlos's Avatar
true^^^
Old Feb 29, 2004 | 06:23 PM
snoochtodanooch's Avatar
Default Re: (Chillinit)
get a thick head gasket, lower the compression and you'll be flying.
Old Feb 29, 2004 | 06:32 PM
soundman's Avatar
Nice job on the Type R, but I agree with what people are saying. Build up a GSR or somthing that is better turbocharged... I would sell that Type R and make quite a bit of cash off it, but just make sure if u do decide to turbocharge that u pay special attention to the fact that if u start breaking things on a Type R the parts are gonna be A LOT more expensive... So get yourself some sweet tuning on that....
Old Feb 29, 2004 | 06:53 PM
Accordcentral's Avatar
Default Re: (soundman)
the new mazda turbo 4 cylinder is a 10:1 engine ive run a few at 15-18 psi.With proper spark and fuel managament running 15 psi on pump remium wont be difficult if you careful. More ignition advance isnt always more power. and mroe fuel isnt always gonna keep it from knocking. Take your time tunning it and youll be surpirsed how much power you can coax out of a boosted high comrpession engine.
Old Feb 29, 2004 | 07:25 PM
ek9vboi2's Avatar
sounds good. 12-11 sec. car to me. do yourself and lower the compression or u can go boom boom. wait thats just 1 boom. hahaha
Old Feb 29, 2004 | 09:44 PM
vteckiller's Avatar
Default Re: (SoHc10Lbs)
thanx. the turbo kit is gonna be installed and tuned at nrg tech. they know there **** there
Old Feb 29, 2004 | 10:08 PM
as long as its done by somebody who knows what their doing i think you'll be ok
93ludesitec
Aug 8, 2006 10:32 AM
Touge Tuning
May 7, 2005 05:28 AM
vteckiller
Mar 7, 2004 08:39 PM
94TealGSR
Jun 5, 2003 08:54 AM
MugenNSX
Oct 4, 2002 03:50 AM
