Golden Eagle sleeving?
Old Feb 27, 2004 | 10:04 PM
Naterror's Avatar
Default Golden Eagle sleeving?
What does everyone with their sleeves think about o-ringing? I know the advantages of it, but I've heard it can create sealing problems.
Old Feb 27, 2004 | 10:13 PM
Kataku2K3's Avatar
Default Re: Golden Eagle sleeving? (Naterror)
We haven't had any problems with o-ringed GE sleeved blocks sealing... That's used in combination with their overbored OE headgaskets and pretty moderate boost levels (~30lbs.)... Just my $0.02
Old Feb 27, 2004 | 10:29 PM
Naterror's Avatar
Default Re: Golden Eagle sleeving? (Kataku2K3)
the reason I ask is because I have a friend who is having Larry at Endyn build his motor and he was told not to do the o-ringing, because when you have the block decked you just cut it off. I'm about to send them my block, but I'm not sure about getting it o-ringed.
Ok, second question. Will I see any problems with blowing head gaskets if not having it done?
Old Feb 27, 2004 | 10:34 PM
Adam F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Naterror &raquo;</TD></TR><TR><TD CLASS="quote">the reason I ask is because I have a friend who is having Larry at Endyn build his motor and he was told not to do the o-ringing, because when you have the block decked you just cut it off. I'm about to send them my block, but I'm not sure about getting it o-ringed.
Ok, second question. Will I see any problems with blowing head gaskets if not having it done?</TD></TR></TABLE>
None of the motors that I build have Orings. I am not saying that the Orings don't work, but most people now don't use them. I have never had any problems without Orings.
Old Feb 27, 2004 | 10:47 PM
Naterror's Avatar
Default Re: Golden Eagle sleeving? (Adam F)
thanks thats what I wanted to hear.
Old Feb 27, 2004 | 10:54 PM
Kataku2K3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adam F &raquo;</TD></TR><TR><TD CLASS="quote">I have never had any problems without Orings. </TD></TR></TABLE>
Yea, that's true too... Our non o-ringed higher boost motors still hold up just fine, but as for the o-ring grooves getting cut off, how much were they talkin about decking?
Old Feb 27, 2004 | 11:00 PM
Naterror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">
Yea, that's true too... Our non o-ringed higher boost motors still hold up just fine, but as for the o-ring grooves getting cut off, how much were they talkin about decking?</TD></TR></TABLE>
well I just put together a motor for a friend and the o-rings are sticking up so if you deck the block any, you going to have to cut them if I'm not mistaken. If I have to square up the block deck they'll get cut, right?
Old Feb 27, 2004 | 11:15 PM
Kataku2K3's Avatar
Oh my bad, you were talking about the copper wire o-rings themselves, correct? I thought you were talking about the o-ring lands in the sleeves getting "cut out"... You're right tho, if o-rings are already installed they're going to get cut/grinded with the block is decked... Peace
Old Feb 28, 2004 | 12:15 AM
ninesecteg's Avatar
try having them step deck it. that has worked the best for me.
Old Feb 28, 2004 | 06:18 AM
turbo96wr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Naterror &raquo;</TD></TR><TR><TD CLASS="quote">What does everyone with their sleeves think about o-ringing? I know the advantages of it, but I've heard it can create sealing problems.</TD></TR></TABLE>
if you have to deck the block then you had some cooling problems that really heated the block surface and warped it., i been using my blocks for 3 yrs now and never had to surface it and never had sealing problems. AEBS blocks with stainless steel o-rings ran up to 37 lbs no problems this year 40-45.
Old Feb 28, 2004 | 09:12 AM
99B16Si's Avatar
i got my block back from GE about 2 months ago and i just had mine step decked. oem headgasket will some copper spray....so far so good
Old Feb 28, 2004 | 09:33 AM
Naterror's Avatar
Default Re: Golden Eagle sleeving? (turbo96wr)
thanks for all the info. I think I'm going to do without o-ringing the block though, doesn't seem like it's going to be a problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo96wr &raquo;</TD></TR><TR><TD CLASS="quote">
if you have to deck the block then you had some cooling problems that really heated the block surface and warped it., i been using my blocks for 3 yrs now and never had to surface it and never had sealing problems. AEBS blocks with stainless steel o-rings ran up to 37 lbs no problems this year 40-45.</TD></TR></TABLE>
another reason to deck the block is to change deck clearance and adjust the compression ratio alittle. The reason I say this is because its cheaper to do this to bump up the compression a few 10th's than to have custom piston made.
hondateg08
Nov 9, 2008 09:27 PM
Project_EK
Jun 9, 2008 07:57 AM
KyleVA
Feb 23, 2007 05:08 AM
FormulaGSR
Feb 27, 2005 10:30 AM
Red99CivicSi
Jun 18, 2003 12:52 PM
