Intake temperature sensor on B16A
Old Feb 27, 2004 | 05:27 PM
XShadow's Avatar
Default Intake temperature sensor on B16A
Hey guys...
I have a intercooler turbocharged B16A and I was wondering what you guys actually do with the Intake Temperature Sensor...
Currently I'm using a K&N conical filter and I the intake temperature was just after that. The ECU was retarding the ignition and leaning the misture due "higher" temperatures on Intake, so I moved the sensor to the front bumper and the car is smoother and actually making more power than before.
What would be the best/correct place to put this sensor? Any tips?
Old Feb 27, 2004 | 06:16 PM
Irishweird00's Avatar
Banned
Default Re: Intake temperature sensor on B16A (XShadow)
bump, ive always wanted to know as well...
Old Feb 27, 2004 | 06:17 PM
c jackson's Avatar
threes
in the stock position
Old Feb 27, 2004 | 07:24 PM
XShadow's Avatar
Default Re: Intake temperature sensor on B16A (c jackson)
The stock position is no more.
I've removed the air box and original air intake, my turbo piping is going thru that hole...
This is a picture of my current setup:
Better to leave after the K&N or relocate it to where the older air intake was?
Old Feb 27, 2004 | 07:30 PM
hpfsi's Avatar
Stock position meaning close to the throttle body. You want the computer to fuel the motor based on the air temp going into the engine, not the turbo.
Old Feb 29, 2004 | 06:48 AM
ScrapinSi's Avatar
Default Re: Intake temperature sensor on B16A (hpfsi)
wouldn't it blow out under boost? Also, if you convert to obd1 doesn't that eliminate the IAT?
Old Feb 29, 2004 | 07:16 AM
Banned
Default Re: Intake temperature sensor on B16A (ScrapinSi)
thats exactly why i didnt think you could do this... i figured it would blow out....
Old Feb 29, 2004 | 09:58 AM
Hoodwinked's Avatar
Default Re: Intake temperature sensor on B16A (Irishweird00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Irishweird00 &raquo;</TD></TR><TR><TD CLASS="quote">thats exactly why i didnt think you could do this... i figured it would blow out....</TD></TR></TABLE>
wrong sir. I tapped mine into my charge pipe. works great. you drill a 5/8" hole, take a rubber grommet from an AEM intake and seal it in with some silicon sealant. then seal the IAT sensor to the rubber grommet when you put it in and presto....its in there. I ran 14.5 psi of boost and it didnt blow out. I still pull 20 inches of vaccumm.
Old Feb 29, 2004 | 10:26 AM
Banned
Default Re: Intake temperature sensor on B16A (Hoodwinked)
good deal, thanks
creepy116
Dec 19, 2007 10:33 PM
dingobat
Aug 6, 2006 11:05 PM
remo
Nov 22, 2005 05:48 PM
b16 matt
Mar 28, 2003 02:40 PM
simonc
Feb 3, 2003 08:05 AM
