Torque Specs for Crower Rods
Old Mar 1, 2004 | 05:09 PM
spooledex's Avatar
Default Torque Specs for Crower Rods
Any one know off hand the Torque specs on Crower rods for a LS B18b bottom end. I think it's 45 ft lbs. but seems high to me since like the old Eagles were only 28. need to know before I seal it up. late
Old Mar 1, 2004 | 05:11 PM
turbo96wr's Avatar
Default Re: Torque Specs for Crower Rods (spooledex)
the crowers i use take 45 ft lbs they make 2 different ones
Old Mar 1, 2004 | 05:42 PM
spooledex's Avatar
Default Re: Torque Specs for Crower Rods (turbo96wr)
Um okay, I will try that. I hope I have the same ones you do. LOL
Old Mar 1, 2004 | 06:46 PM
Savalicious's Avatar
Yeh the torque spec is 45 ft.lbs, but make sure you use the Lock Tite anti sieze that they recomend for lube, when torqueing anything it is critical to use the recomended lube for the manufacturers suggested torque spec. to avoid over or under torqueing.
dingusjt
Feb 6, 2015 08:59 AM
turbotypeR@SPEC
Mar 10, 2005 09:49 PM
b00stedbyFastrax
Jul 25, 2002 09:24 PM
b00stedbyFastrax
Jul 24, 2002 12:12 PM
