square ports on FI setup??
Old Feb 28, 2004 | 06:04 PM
JBk24crx's Avatar
Default square ports on FI setup??
all motor engines gain a lot of power with square ports.are square ports even needed on a turbo engine.Are the gains even greater on a turbo setup.
Old Feb 28, 2004 | 07:11 PM
Justin Olson's Avatar
Default Re: square ports on FI setup?? (JBLSVTEC)
Believe me or not, square ports are not as efficient as round ports. The only reason to run a square port is when you can't make your round port any bigger. You'll see a lot of v8's with square ports because they have the pushrods taking up realistate in the head. They are trying to get every last big of port volume. If you do this to a honda head, I think you would kill port efficiency.
Justin
Old Feb 28, 2004 | 10:21 PM
kyosoeg6's Avatar
Default Re: square ports on FI setup?? (olsonjus)
ive heard that also but i talk to wil from exospeed and he stands behind his square ports.
Old Feb 28, 2004 | 11:09 PM
Joseph Davis's Avatar
Default Re: square ports on FI setup?? (kyosoeg6)
Square ports = twice as much drag on the intake charge trying to reside in one of the port's corners.
Maybe Wil at exospeed is getting such good results from the charge forming it's own boundary layer around the corners, and effectively making the port geometry oval again?
Prudz_lude
Apr 21, 2008 12:11 PM
pootie.teng
Jul 5, 2006 10:35 AM
JBk24crx
May 29, 2003 03:37 PM
Bnjmn
Mar 6, 2003 05:52 PM
slowcivic
Jan 31, 2003 02:12 AM
