eight injector manifold...
Old Feb 28, 2004 | 03:39 AM
Nid Styles's Avatar
Default eight injector manifold...
I know JG used to make one, but do they still make one? Does somebody else make them, though? I'm just looked to see what's available.
Old Feb 28, 2004 | 04:34 AM
JDMorgan's Avatar
str does right?
Old Feb 28, 2004 | 05:16 AM
Nid Styles's Avatar
Default Re: (KraZEtEggIE)
I don't know that's why I'm asking. I haven't found one yet.
Old Feb 28, 2004 | 06:06 AM
turbo96wr's Avatar
Default Re: (nd_styles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nd_styles &raquo;</TD></TR><TR><TD CLASS="quote">I don't know that's why I'm asking. I haven't found one yet.</TD></TR></TABLE>
you have to buy it from edelbrock now just buy it out of summit mag.....
Old Feb 28, 2004 | 09:39 AM
JDMorgan's Avatar
look into str i think they do. i just dnu wanna do ur research for ya
Old Feb 28, 2004 | 02:05 PM
Nid Styles's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KraZEtEggIE &raquo;</TD></TR><TR><TD CLASS="quote">look into str i think they do. i just dnu wanna do ur research for ya</TD></TR></TABLE>
Yeah, yeah I know. Sorry, I was just hoping someone would be able to tell me outright. I can be lazy sometimes right?
Old Feb 28, 2004 | 08:49 PM
JDMorgan's Avatar
hey man mi just as lazy. i wanna know now but moving th mouse is too much work to find out.
Old Feb 28, 2004 | 09:14 PM
IntegracinGSR's Avatar
Edelbrock sells one..
Old Feb 28, 2004 | 09:44 PM
XShadow's Avatar
Default Re: (IntegracinGSR)
I think Venom also does sell.
Old Feb 29, 2004 | 01:41 AM
JR_SHIFTY's Avatar
I'm not sure if this helps any but I saw this thought it might
http://www.modacar.com/product...DAINM/
Old Feb 29, 2004 | 03:35 AM
Nid Styles's Avatar
Default Re: (JR_SHIFTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JR_SHIFTY &raquo;</TD></TR><TR><TD CLASS="quote">I'm not sure if this helps any but I saw this thought it might
http://www.modacar.com/product...DAINM/</TD></TR></TABLE>
Thanks for that.
I see the JG can only except a 65mm TB. Can it be bored to 70mm+?
Old Feb 29, 2004 | 09:32 AM
JDMorgan's Avatar
isnt the iacv in the way to bore over like 66mm? i suppose you could put an offset on the tb bore and use some sort of spacer? if you offset the hole you should be abled to bore it up to like 72 i would think. i never saw a 8 injector venom manifold, if u seen one post pix.
Old Feb 29, 2004 | 07:14 PM
lagingtorpe's Avatar
is there a clear advantage to this setup? just asking... is it really neccesary?
Old Feb 29, 2004 | 07:26 PM
ek9vboi2's Avatar
y would you need 8, when 4 can pretty much handle it all? just get bigass injectors
Old Feb 29, 2004 | 07:40 PM
Flamenco-T's Avatar
Default Re: (SoHc10Lbs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoHc10Lbs &raquo;</TD></TR><TR><TD CLASS="quote">y would you need 8, when 4 can pretty much handle it all? just get bigass injectors</TD></TR></TABLE>
some people are just born gangsta...
Well sometime running 8 at lower duty cycle is better than 4 injectors at high duty cycle..but the main reason is if you;re running meth, you may run out of fuel flow early, therefore you need 8 to either kick it 4 at first and 4 injectors later.
stan
Old Mar 4, 2004 | 05:06 PM
Default Re: (Flamenco-T)
oic stan!
Old Mar 4, 2004 | 09:55 PM
JDMorgan's Avatar
by using 8 injectors 4 are in use like normal injectors and the extra 4 are only used when needed if the setup is done right. this will make your cars low end torque higher. this was proven on gmc syclone/typhoons, and im sure all the same rules apply to imports. major differance was the syclone used 6 normal sized injectors and one big injector.
Old Mar 5, 2004 | 10:01 AM
Nid Styles's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">
stan</TD></TR></TABLE>
You read my mind there. I plan on running ethanol, though.
Old Mar 5, 2004 | 12:15 PM
JDogg's Avatar
by using 8 injectors 4 are in use like normal injectors and the extra 4 are only used when needed if the setup is done right. this will make your cars low end torque higher. this was proven on gmc syclone/typhoons, and im sure all the same rules apply to imports. major differance was the syclone used 6 normal sized injectors and one big injector. </TD></TR></TABLE>
thats not an issue with proper engine management......
hbyrd8701
May 18, 2008 08:00 PM
b00stedbyFastrax
Jun 5, 2006 02:42 PM
EJ8 GSR-T
Sep 4, 2005 02:03 AM
donkiman
Oct 8, 2004 08:57 AM
IVI
Aug 29, 2004 04:13 PM
