Cam Caps
Old Jan 1, 2012 | 10:08 AM
jollygr33n's Avatar
Default Cam Caps
I'm looking at buying a built gsr motor, but apparently it doesn't have cam caps. If I purchase new cam caps or use some from another engine will I need to have the cam journals line bored with the new caps? Any thoughts/ help is greatly appreciated.
Old Jan 1, 2012 | 10:22 AM
HPTautosport's Avatar
Default Re: Cam Caps
Yes.
Old Jan 1, 2012 | 10:45 AM
efHondefender's Avatar
it's a paper weight. Don't buy it. If you get some other caps, they'll just line up to one side or the other. So, if you try to line hone, you'll probably have to go larger than the factory specs allow to get a even hole. It's not worth the trouble and probably won't work anyway. I'm a core engine wholesaler and I sell to Larry at Endyn. He wouldn't take a b-series vtec head if it doesn't have the original caps even if I sold it to him for $50. That should tell you something
Old Jan 1, 2012 | 10:53 AM
H22AFerio's Avatar
are you talking about cam caps or are you talking about the cam covers? if you talking about these witch I think you are you can just bolt them on and go. but like the other said if you have to get the actual cam caps its not worth it.
Old Jan 1, 2012 | 11:14 AM
00Red_SiR's Avatar
All Motor Mentor
^^^^those are called cam rails. The caps are what's underneath them and hold the cams down (for anyone that wasn't sure).
Old Jan 1, 2012 | 11:37 AM
H22AFerio's Avatar
yup I knew what they were I just forgot what to call them haha
Old Jan 1, 2012 | 11:40 AM
BoostedEgHatchFl's Avatar
Yea its not the covers. Its the cam caps. So it wouldn't be worth it to get the motor?
Old Jan 1, 2012 | 12:14 PM
jollygr33n's Avatar
Thanks everyone for the quick replies. The info is helpful.
Old Jan 1, 2012 | 01:27 PM
Blove1991's Avatar
You could still use the block if it is built and find another head.
Old Jan 1, 2012 | 05:31 PM
vwbased's Avatar
have a nice day
Old Jan 1, 2012 | 05:48 PM
H22AFerio's Avatar
Originally Posted by vwbased
Makes you wonder where the original cam bearing caps went. There ought to be a law against losing the damn cam bearing caps.
Im not tring to be rude but wtf are cam bearing caps?? there are no cam bearings in a honda head?
Old Jan 1, 2012 | 06:00 PM
vwbased's Avatar
have a nice day
Old Jan 1, 2012 | 07:17 PM
Jhicks's Avatar
yup
Old Jan 2, 2012 | 12:14 PM
H22AFerio's Avatar
The caps are the top half of the bearings. There are no bearing "inserts" in a honda head.
ok
NA JDM GSR
Oct 23, 2006 08:20 AM
freeagent32
12
Jul 13, 2005 03:55 PM
216.226.142.95:27016
Jun 27, 2003 10:22 PM
CrazyKoreanCrx
May 31, 2003 02:05 PM
