ITR cams over GSR?
Old 01-05-2012, 12:48 PM
Listerofsmeg's Avatar
Default ITR cams over GSR?
Is there a huge benefit to running ITR cams over GSR cams with an S372R on a sleeved B18?
My thought process was that the higher lift and duration of the ITR cams might help bring the turbo in slightly sooner and produce slightly higher peak power? Has anyone swapped these out back to back? what were the benefits? area under the curver significantly changed?
Am i wrong in that assumption? i am very close to getting the car tuned so was seeking advice as to if i should swap them out if the benefits are large....
Any advice welcome!
Old 01-05-2012, 01:14 PM
racebum's Avatar
Default Re: ITR cams over GSR?
remember one car that was around 400whp that picked up 40whp with this change
Old 01-05-2012, 01:16 PM
ok thats a +1 for ITR
thanks
anyone else? specifically on cars that are running 600hp+
Old 01-05-2012, 01:41 PM
mines13's Avatar
thanks
I'm doing my build with ITR cams simply based on the fact that I can not see one post where people didn't gain an advantage switching to them from the GSR's... I do not think you can go wrong. PS your name owns all.
Old 01-05-2012, 02:29 PM
lsturbo33's Avatar
If your going for 600 then go with ITR cams.
Old 01-05-2012, 03:55 PM
gringotegra's Avatar
https://honda-tech.com/forums/showth...t=Gsr+itr+cams
I did that comparison about 3 years ago. Good for a Solid 40whp give or take at the same boost level.
I will be testing some new cams here shortly that i expect to be much cooler than the ITR's, as far as i know nobody else has them yet
Old 01-05-2012, 03:58 PM
blinx9900's Avatar
poor dead hourse, GSR cams have made over 800whp but people have also made 800whp with 3" turbo back exhaust... It will work, but it's not as efficient and you will make more power with the ITR cams just like an 800whp car stepping up to 4" exhaust will make more power. ITR cams will make more power on nearly any setup opposed to GSR, maybe GSR will shine more on a small garret/log mani type kit with a small turbo, but that's about it imo.
Old 01-05-2012, 04:20 PM
nealnanoHX's Avatar
ITR/CTR cams are the best OEM cam and are great for pretty much any setup. If you can get some then do they are worth the coin. But as said GSR cams have proven also to make power past 700hp no problem.
Old 01-05-2012, 06:01 PM
racebum's Avatar
LOL, exactly the person i was referring to when i said 40whp
Old 01-05-2012, 07:30 PM
A BeastyDC4's Avatar
we made 365 on a topmounted 60-1, completely stock gsr with type r cams... itr are definitely the way to go
Old 01-06-2012, 02:43 AM
EddieCRX's Avatar
Just curious?
84mm built block
stock port (B16) head
up rated valve train (stock size)
Precision S372R
Will the GSR cams support a good enough power band for the S372 based on turbo's peak torque, not sure how far people rev out the GSR cam and still make power?
Seen many cars drop out of the power band between shifts due to small cam and big turbo?
Old 01-06-2012, 05:01 AM
Thanks guys, i think you have helped steer my decision.
Eddie, bit confused about your comment, gimme a buzz if you get a minute and we can have a chat
Old 01-07-2012, 07:44 PM
hell0curry's Avatar
with a set up with itr cams would you need to upgrade your injectors?
Old 01-07-2012, 07:50 PM
sanman000719's Avatar
b16a2/pt67 .70-.82/rc1000's gsr cams 610@25psi
on e85 sorry forgot to post that
A13sechatch
Mid-Atlantic (Sales)
11-19-2008 04:51 AM
GSRintegra_Bob
10-10-2005 09:49 AM
GoodFella
02-18-2004 12:58 PM
Quick Reply: ITR cams over GSR?
