blox b on boost.
Old Jan 9, 2012 | 07:38 PM
Civic89stdB16's Avatar
Default blox b on boost.
My car is breaking up like crazy right at the vtec crossover and wont go away up higher in the rpm's either. it goes away if we disengage vtec. what is everyone setting there cam gears to and y would it do this. My boy has been trying to get them to work for me but cant firgure them out. my car is on e85 also. compression is 9.5 to 1. turbo is a hx35 7 blade. its a track car not a street car. If i swith back to stock gsr it goes through vtec fine. lmk thanks.
BTW. I seen tons of peple running these cams making big power without any problems just not me.
Old Jan 9, 2012 | 07:44 PM
TheShodan's Avatar
Moderator
Default Re: blox b on boost.
Why are you using such a small turbo for such a cam like this.. Those (or similar) need to be reserved for larger turbochargers over 61lbs/min. Using those on such a small unit wouldn't help you with power anyway. We don't "set these up" like they're some sort of NA car because of the fact that it is forced induction, which changes the equation exponentially.
I know I'm not being the most helpful directly with your question of cam gears, but really, its best to stay with your GS-Rs for this turbocharger. Use the Blox for something else.
Old Jan 9, 2012 | 09:16 PM
im getting a bw366xl in a couple of weeks and will be putting them back in. if i can get them to work.
Old Jan 9, 2012 | 09:19 PM
i have seen them also on 350whp turbo cars with a 57 trim on them and work. so my turbo should work ok but idk y it aint.
Old Jan 10, 2012 | 12:13 AM
blwncr's Avatar
Could it be valve springs causing float? Just curious as im experiencing similar issues with break up/surging after vtec engagement with my F20B blue top turbo. Sweet off vtec, break up on vtec, no det anywhere,11.8 afr. Im running 9.5:1 comp top mount and GT35 turbo
Old Jan 10, 2012 | 04:24 AM
TempestRacing's Avatar
i had a car kick my butt on the dyno years ago with a similar problem (however it had stock cams in it)...i spent a lot of time trying to figure it out, eventually got so frustrated i just pulled the head to take a look. turned out the car had a bunch of bent valves. ran perfectly as a NA car, discovered this after we put the turbo kit on and it just would not work with vtec. put some new valves in it and its still running to this day.
i have also seen people have their low cam / high cam fuel tables so far off that as soon as the car gets into the high cam map it goes so lean or so rich so quick that it never registers on the wideband before it starts turning into a bucking bronco.
post up some logs
Old Jan 10, 2012 | 05:56 AM
kyden's Avatar
are you running a log manifold?
Old Jan 10, 2012 | 07:51 AM
HiProfile's Avatar
Set vtec far lower and set boost as low as you can go. Then tune upwards with PSI, then do the same except with vtec set very high. Finally set x-over and fine-tune that spot if needed.
If that's not it, it could be floating valves. Anything bigger than ITR cams do not like stock valve springs.
Old Jan 10, 2012 | 09:02 AM
its not valves floating. i have blox springs and retainers. it turns into a bucking bronco at vtec. idky. i just want it to work and go away.
Old Jan 10, 2012 | 10:32 AM
Hidenplanvew's Avatar
might need a retune
Old Jan 10, 2012 | 07:17 PM
blwncr's Avatar
What style of manifold are you running?
Old Jan 11, 2012 | 06:58 PM
rico892002's Avatar
hmmm...there fine in my car..my car needs to be retune with them tho..i had gsr cams in my set up and thur these in..run fine..vtec crossover is fine...i got on it a little bit, but like i said i need to retune the car
Old Jan 11, 2012 | 07:06 PM
CDecker0218's Avatar
Originally Posted by Hidenplanvew
might need a retune
Thats what im thinking
Old Jan 11, 2012 | 07:16 PM
rico892002's Avatar
^^^^thats what it sounds like to me..i have my gears set a 0,0 just til i get on a dyno..blox specs say +1 or +2 degree on intake and 0 on exhaust..also did u change the valve lash to blox specs
Old Jan 11, 2012 | 07:23 PM
92redhatch's Avatar
I have blox b's and they work great. I have them set to 0,0. My vtec is set to 4000rpm. I'm on a 6765 motor is a lsvtec 84x89. I'm actually going for 800+whp soon
Old Jan 11, 2012 | 08:44 PM
im on a cast log right now but im switching to a topmount with a s366xl. the walve lash was redune for the blox cams. the settings were at 0 and 0 and the vtec was set at 5700.
Old Jan 12, 2012 | 07:27 AM
kyden's Avatar
there is your main problem. coupled with a turbo too small for your cam setup.
Old Jan 12, 2012 | 09:31 AM
thanks brop. thats y im switching to a topmount and a 366xl. if my block gets sleeved then im going to the beast s372.
lskid98
Sep 12, 2007 06:50 PM
BLKCivicPorscheStyle*
Mar 21, 2006 09:14 AM
TeamCracka
Sep 9, 2004 07:46 PM
allmotorEG-SI
Jun 4, 2002 11:47 AM
integRated109
Aug 9, 2001 09:47 PM
