What crank should I use
Hey guys. I'm about to fully build a lsvtec. And I have a choice of using a stock crank or a golden eagle knife edge. I'm putting eagle sleeves, eagle rods, JE piston. Please tell me what y'all think the best choice is.
Re: What crank should I use
the oem crank is factory balanced and is probably stronger.
you an knive edge a oem crank. you dont want to use some aftermarket crank
I would stick with an OEM crank. I have never seen an OEM B series crank fail ,not saying it has not happened but they can handle 800+HP no problem when balanced. Knife edging is not necessary either, boosted motors like the inertia, also the reason why a stock flywheel is generally a better choice when boosting. It all depends on the driving and goals for the car.
cyrix12
08-14-2005 07:02 PM
