Can anyone ID that noise? fuel pump?
hi guys,
i have similar noise on a friends car and we cant figure out what is it .
please take a look:
http://www.youtube.com/watch?v=jPjFZCIdaUA
thanks
please take a look:
thanks
Re: Can anyone ID that noise? fuel pump?
hi guys,
please take a look:
thanks
please take a look:
thanks
ok I hear it now lol I cant listen to it verry loud at work so I just hooked up my ear buds from my Ipod. Tony is right it deff sounds like a boost leak. check all your couplers for holes and ensure your T-Clamps or what ever you use are tight and your factory/After Market Bov gasket is not leaking or cracked. good luck man
oh ok I thought you were talking about the SRT4 in the video?? what bov are you using? your blow off valve my be adjusted tighter I had this problem on the dyno when I was tuning the boost was leaking out the bov I just tightened it up and solved the problem.
i also assumed its a bov issue,
the car had a fake type-s and i replaced it with a type-s and then a type-rz
i adjusted all of them so i wont hear air rushing in the charge pipes,
Next on the list could be your intake manfiold gasket or throttlebody gasket.. Are there any vacuum leaks? I had times when the gasket leak was very minor and the ECU/IACV basically trimmed it out and the car still idled properly and had proper vacuum. But upon boost, it would create a high pitched sound similar to the video.
yeah those Type S knock offs suck the construction over all is good but the Diaphragm inside is made of a verry cheap rubber and tears pretty quick. my buddy ran one on his DSM and it ripped after a few pulls down the track haha then the boost just leaked right past the diaphragm. but you said you swapped it for another Bov was it a reputable brand?
thanks for the replys guys,
i checked intake vac leaks yestarday with a carb cleaner, i found that the IACV gasket was leaking, i replaced it and nothing changed, i sprayed the whole intake manifold around the tb, fitv, injectors, iat, and couldnt find anything else,
i switched the fake type s to a real type s and the noise was still there and then i replaced to a type rz and determined its not the bov.
my new directions are:
fuel pump/ fuel pressure
or the seal inside the compressor housing,
yeah its wierd, its my first time too
i think its the rubber seal that seals the comp housing to the core, its a td04, the compressor is held with a c clamp,
i capped both compressor inlet and outlet and used a vacume gun on the boost line port and it dosnt hold vacume,
well see tommorow,
well see tommorow,
well see tommorow,
well see tommorow,
sounds like the fuel pump is going out. you can go to a dyno and do a pass and check the fuel pressure and see if there's a drop in pressure.
