Help with mani choice
Old Jan 4, 2012 | 06:20 PM
nealnanoHX's Avatar
Default Help with mani choice
I need some advice on which mani to choice for my build. I was going to use a Ebay cast Inline Pro knock off but decided to go with something better. So I am looking at the Go-Autoworks log mani and the SP log mani. Both are the same price and very similar in design. However from what I can see the SP mani seems to have the WG flange located more in the center where the Go-Auto seem to be more on the #3 cylinder (I think it is) and may have boost creep. Thoughts on this and or experience?? Also any other good AC PS manis that are not cast?
Old Jan 4, 2012 | 07:05 PM
Hidenplanvew's Avatar
Default Re: Help with mani choice
You want the WG as center as possible on the collector.. Blox has a cast iron that works
Old Jan 4, 2012 | 07:11 PM
nealnanoHX's Avatar
Yeah I have the Blox/Inline Pro knock off, was looking for something better.I know about WG placement thus the comment on it. However the Go-Auto mani is only slightly off center so I was looking for experience with these.
Here is the mani I have right now just to show why I was looking at using another. I know it will be fine for my current 300whp goal but I also want quality, not using the Egay WG.
Old Jan 4, 2012 | 08:03 PM
SilverEK96's Avatar
Inline Pro also has a stainless steel log manifold as well. Thats what I was using on my previous setup and never had any boost creep issues at all. Its A/C and P/S friendly and can handle upwards of 500 plus whp. I still have my old complete setup, pm if your interested
Old Jan 4, 2012 | 10:10 PM
TheShodan's Avatar
Moderator
Go-Autowerks and Spool'n are both great. The spoolin' does not creep at all. Never has. Please check Californiadad's setup. He's over 450whp on that same log with no creep. Vaccum lines, good waste gate / turbo size combination are the best factors to eliminate boost creep. Leave the Blox one alone.. Bye-bye..
Old Jan 5, 2012 | 05:32 AM
nealnanoHX's Avatar
Yeah I dont want to spend $500 on a cast mani, For that money I would get a Min Ram. What all do you have in the turbo kit, details please. I was looking a piecing a kit together but then I found the Go-Auto has a kit withe all they stuff I was looking at anyway for the price range I was will to spend, just needs fuel injectors.
Cool thanks for you input Shodan.
Old Jan 5, 2012 | 07:47 AM
SilverEK96's Avatar
PM sent
Old Jan 5, 2012 | 02:21 PM
Shodan you dont like the cheap blox?
Old Jan 5, 2012 | 03:44 PM
EsotericImage's Avatar
Retired Moderator
the Go-Autoworks has the correct mani with WG placement fed by all 4.
they just havent updated their pics on their site.
I would do the Inline Pro if i had the $$ to do so.
Old Jan 5, 2012 | 04:31 PM
nealnanoHX's Avatar
Inline Pro and Go Auto are the same $300 for the log mani. I am looking at the complete kit with this mani and a Garrett 57 trim pretty good deal for what you get, plus time saved not having to fab and modify.
88EF4dr
10
Sep 16, 2010 10:42 PM
99importnizl
Jun 2, 2003 04:08 AM
Chris_R
May 19, 2002 01:54 AM
