Lsvtec dies when hits boost
Old Dec 15, 2011 | 03:56 PM
95integra123's Avatar
Default Lsvtec dies when hits boost
I got my car tuned this week, my tuner tells me that now as soon as i hit 1.3psi the motor just dies, like as if you shut off the key. Heres some info on it, lsvtec b18b1 bottom b16a top end, has a 60-1 , block guard arp head studs rod bolts, golden eagle intake gasket and lsvtec kit, and skunk 2 intake manifold. Its on 10 pounds, He swaped out map sensors, tps, retimed it, and i forgot what else he tried, but i think it might need 1 or 2 bar map, he doesnt anyway i was hopeing that i could get some
Ideas from you guys.
Old Dec 15, 2011 | 04:10 PM
EsotericImage's Avatar
Retired Moderator
Default Re: Lsvtec dies when hits boost
did he use a 3 bar map?
Old Dec 15, 2011 | 04:56 PM
92redhatch's Avatar
Maybe boost cut....
Old Dec 15, 2011 | 05:06 PM
No hes used a stock one, thats why i think we should try a 1 or 2 or 2.5 bar just to see if it works, i dont know how a stock one should Act on 10psi
Old Dec 15, 2011 | 07:57 PM
siregcivic's Avatar
stock should be fine for 10 psi as far as i remember stock reads like 11.7 or something like that
what are the afr's when it starts hitting boost, is there a wideband o2 hooked up to the car? is it hitting boost cut? could be running too lean could be running too rich could be anything we need more info
Old Dec 15, 2011 | 08:51 PM
He said when it does it that it leans out, there is a wide band on it, im not sure of afrs, but the turbo wants to spool but if it does the motor just shuts down
Old Dec 15, 2011 | 09:07 PM
W!d3b0dYr3X's Avatar
we need more info on the setup. what size injectors, whats it being tuned on, etc etc. i wouldnt suggest going into boost much if its going lean even on 2 psi. leaning the motor out is dangerous.
Old Dec 15, 2011 | 09:12 PM
There dsm 450s, hes using chrome pro, we tryed using stock injectors, stock ecu hondata ecu, chipped p28, and they all do it, we turn the distributor boths ways, but it still died, it runs fine when its not in boost,
Old Dec 15, 2011 | 10:15 PM
mmcd's Avatar
i use to have a lsv-t on 10psi and i did have a 3bar map. there like $50 on ebay i would get one. I had this happen to a frind of mine car and it ended up being a injector wire got "cut" somehow. It was like as soon as it started to spool the motor would shut off basilly like fuel cut.
Old Dec 16, 2011 | 07:27 AM
nealnanoHX's Avatar
You have resistors or a resistor box for those DSM 450s right??? Sounds to me like there is something in the wiring, ECU or tuning. Try using Hondata or Neptune they are way better than the $50 Crome chip. The stock MAP can see 10.68psi I think that is its limit, I dont think that is your problem. This is why I always drive the car NA for a while to break in the new motor and/or to make sure everything is running correctly, then I do the turbo. That way if something weird happens like this I know it is caused by something that just changed with the adding of the turbo.
Old Dec 16, 2011 | 11:53 AM
crvtectim's Avatar
Did you gap spark plugs around .028 - .030?
Old Dec 16, 2011 | 12:09 PM
nealnanoHX's Avatar
^ If running a stock plug at a stock gap with boost it can blow out the spark basically. Need a 1-2 step colder plug a gapped as said above. Oh also copper NGK R plugs are what I like to use, copper conducts the heat away better that the iridium OE plugs do. I just change them out every 10-20k depending on how I have been driving and the quality of the fuel. Here in Arizona we only get 91 at the pumps and it can be poor quality at some gas stations.
Old Dec 16, 2011 | 12:21 PM
i really appreciate all the suggestions, im going to pick it up today and try some things out, he said after i figure it out hes going to touch up the tune for free.
so first thing im going to do is try getting spark plugs for it, he told me to consider a new fuel pump(oh i forgot to mention it has a walbro 255) but i will keep updated. thanks
(also more post/suggestions are encouraged lol)
Old Dec 16, 2011 | 02:04 PM
crvtectim's Avatar
The 255 is perfectly fine for your setup. I'm starting to get a certain feeling in regards to said tuner...
Old Dec 17, 2011 | 05:37 PM
Update
I put my stock p28 on and it builds up to 10 psi just fine, but idles really rich and surges, soooo is that safe to say its the tune?
Old Dec 17, 2011 | 05:40 PM
Retired Moderator
Originally Posted by 95integra123
Update
LOL your asking us?
this would be a question for your tuner
Old Dec 18, 2011 | 03:21 AM
siregcivic's Avatar
95integra123 where are you located at, i have 2 different style dynos i can rent... either a dynapack for 100 or a mustang for 50
Old Dec 18, 2011 | 03:24 AM
siregcivic's Avatar
here is a dyno graph of my friends h22 built turbo on 14psi on a dynapack that i tuned this wasnt the finished graph i forgot to get a pic of that one but at 6500 the afrs dropped to 11.1 that was the dip in the graph
Old Dec 18, 2011 | 06:39 AM
Blown90hatcH's Avatar
Update
Find a new tuner man. He should be able to tell you what is wrong with your car.
Full boost at 7200rpmish? Do you have a boost log on this? Powerband looks horrible.
Old Dec 18, 2011 | 07:30 AM
92cxturbo's Avatar
the tuner doent know what he is doing, pretty obvious. Did he even add boost tables to your map?, lol
Old Dec 18, 2011 | 03:17 PM
crvtectim's Avatar
And, please, no more 10psi pulls with your stock P28! Haha, damn.
Old Dec 19, 2011 | 12:41 AM
siregcivic's Avatar
it was a fully built 8:1 compression h22 motor i dont have the boost log, but it didnt spool till way late i dont really know the size of the turbo either, it was a twin scroll with a single wastegate, i had vtec set at 5000 and no matter where i set it, it didnt help the spool time, i could have revved it higher but the owner of the motor didnt want me to go past 7500
here is some pics of the setup its long gone he sold it and got an sti
all the runs were 3rd gear with an h22 tranny i probably should have done 4th gear but it was on a dynapack so i figured it wouldnt matter
on the road it was a different story once you got into 4th gear it was full boost by 5k that turbo spooled up way late idk if its because of the 3 inch charge pipe all around and huge intercoler, long primaries on the turbo manifold idk but it spooled way late, and really nothing i did fixed it, but it was stupid fast thats all i remember i took a friend for a ride and he almost pissed himself lol
Hiboost 2.0
Apr 17, 2013 08:14 PM
1badteg
Jun 24, 2009 02:00 PM
LSej1
Jul 19, 2008 03:51 AM
the.hamburglar
Aug 2, 2007 02:44 PM
Crazy Cooter
Nov 4, 2003 05:02 PM
