journal or ball bearing?
Old Dec 5, 2011 | 03:48 AM
spdrmn's Avatar
Default journal or ball bearing?
so....journal or ball bearing? pros vs. cons? wich do you prefer and why?
Old Dec 5, 2011 | 04:11 AM
Gsrsi's Avatar
Default Re: journal or ball bearing?
https://honda-tech.com/forums/forced-induction-16/gt35r-2838725/
Old Dec 5, 2011 | 04:21 AM
rich7777's Avatar
It depends what you want from the car ??? Whats its use ?
Old Dec 5, 2011 | 05:27 AM
spdrmn's Avatar
use as dd. probly be running ~8-10 lb. for street. i hear boosting by gear is good. never done it so ill try it out. id like to see around 400-450 hp.
Old Dec 5, 2011 | 06:34 AM
phat00civic's Avatar
Curious how you went from ball bearing vs journal to 400-450hp at 8-10 psi? Me personally the ball bearing will be faster to spool, but in terms of life, they both last the same, just make sure they are appropriately receiving oil and run a turbo timer for optimal cool down time.
Old Dec 5, 2011 | 06:45 AM
spdrmn's Avatar
im sorry. i should of explained better. what i meant was i will boost with about ~8-10lbs (~350ish hp) on day to day driving, but i wanna be able to get up to ~400-450hp on higher boost and not worry bout my turbo blowing up or burning out. im guessing this will happen at around 14lbs of boost.
yea, im ubber tired. so my bad for not making that clear earlier.
Old Dec 5, 2011 | 07:00 AM
10 PSI on different turbos will have different outputs. Now you want to have two different tune's essentially, one for DD and the other for track, correct? With that said, what gas will you run? Also what motor are we talking about? 400-450hp will need some internal work, where 350whp shouldn't be an issue, but again what motor?
Old Dec 5, 2011 | 07:13 AM
spdrmn's Avatar
its on a k20z3. internals are built up already in preperation of this build. i have brian crower stage 2 n/a cams in it now. that may change when i do the build, gonna try those cams for now cuz they are already in the car. got wiseco pistons and eagle rods. yes, i essentially am going to have 2 tunes that i can upload via flash pro.
Old Dec 5, 2011 | 07:43 AM
Sorry but I am not the best to ask in terms of the K series motor, although I can speak on behalf of D's and B's and turbo's. Someone else will have to help you pick the turbo to meet the application your after though. From what it seems your well off, although those cams concern me.
Old Dec 5, 2011 | 08:03 AM
spdrmn's Avatar
the cams have suited me well for my n/a motor. they have been fun, but then again will they suit the needs of my motor for f/i. that is the question. ill run em for a week and see how they perform unless i hear otherwise. if anything ill just pick up another set and replace em when i do the build.
Old Dec 5, 2011 | 12:51 PM
TheShodan's Avatar
Moderator
here's how he answers the question of the right turbo. As ball-bearing cartridges, though nice, normally are not necessary unless doing some types of endurance racing.
Budget (to spend on a turbocharger only)
type of racing -- Sounds like street/strip
type of exhaust manifold use.
Do you plan to keep A/C and/or Power Steering?
Chassis?
what kind of maximum power on which fuel? (you said 450whp, but not which fuel to use)
Journal or ball-bearing is an easy question.. its everything else that's making it difficult.
Hellahflush
Mar 27, 2015 05:15 PM
ashtons300zx
Jan 18, 2013 06:59 AM
jtbsurfer
Apr 30, 2007 03:12 PM
Kack
Jan 27, 2004 02:35 PM
