hole through exhaust manifold stud port
Took my gsr head to a local shop to remove a stripped exhaust stud out and notice today that there is a hole where the shop took my stud out. I can see pretty much the inside of my head. Talk with the shop and they said that the hole was already there. Is there anyway I can weld the hole and re tap it? Any ideas? Will this do any damage to my motor? Thanks
Re: hole through exhaust manifold stud port
This happens way too much, who worked on it at the machine shop? Probably a first year apprentice. Make them fix it! It was not there already that's retarded.
Yes they must of drilled the hole to deep to where I can see right through the head. I'll take a picture ignite once I take off my turbo manifold. I just inserted a bolt in the stud port for now and it still leak but not as much. The hole is pretty ****ed up to where I can see the block surface. Is there some kind of oil port on the passenger cylinder head? will this be the problem my engine is idling rough do to lack of compression? Should I just weld the hole and re tap it?
The machinist at the shop said that the hole was already there and nothing he can do about items told me I should be glad the stud was out.
I wouldn't worry about it, just use some good sealant around the threads.
The standard Mitsi Evo's have all the bottom studs onto the exhaust manifold through an oil gallery.
I would have the shop fix it, it is there f^&k up anyways and they just are not owning up to it. I had a head destroyed by a machine shop, it was a real nightmare to deal with them.
rocketfuelcerx
08-22-2005 02:31 PM
