are these really darton sleeves
Old Dec 13, 2011 | 08:26 AM
92frostwhtdb2's Avatar
Default are these really darton sleeves
interested in purchasing this block as a back up, seller ad says there Darton bored to 83mm. looking at the pictures it seems to be an iron lining with aluminum outer, with an obvious block guard.looking around im thinking they might be the open deck no flange replacement type sleeves but im not to sure.
http://i1238.photobucket.com/albums/...119_161920.jpg
Old Dec 13, 2011 | 09:05 AM
Muckman's Avatar
Moderator in Chief
Default Re: are these really darton sleeves
Looks like factory sleeves with just a block guard to me. Ask the seller to produce the receipt.
Old Dec 13, 2011 | 10:06 AM
alperx's Avatar
as Muckman stated, these are not genuine dartons.
absolutely.
Old Dec 13, 2011 | 10:14 AM
That's what i was thinking they look pretty thin,but figured they might oem replacements,thanks.
Old Dec 15, 2011 | 07:57 AM
Darton's Avatar
Its hard to say if they are Darton 300 series sleeves due t oall the dirt. I would not recommend buying this block. If you look at the left middle cylinder the outside of the stock casting has been broken off possibly when the block guard was installed. If it happened after this could cause the stock casting under it to crack.
TravisBiggie
Oct 18, 2013 05:08 AM
Woody.
20
Feb 28, 2011 05:47 PM
2LiterTurboSeR
Jan 9, 2010 02:29 PM
Boosted_B_Series
Dec 17, 2007 04:27 PM
hbvetteslayer
Jun 26, 2003 08:56 PM
