GT3582R GSR Tranny Selection Street/Strip Car
Looking for opinions with reasons for transmission selection for my GSR with gt3582r turbo, power will be around 375/550 based on pump/race and dont tell me to search i tried its just as easy for you to answer. preferrably a tranny with a lsd, I will be probably be purchasing a brand new one from honda/acura so it has to be from a usdm model what should i choose and why GSR, Type R, or is a JDM option from a civic or something better?
Moderator
Re: GT3582R GSR Tranny Selection Street/Strip Car
That type of LSD (Torsen) from the OEM is not going to help with that kind of power. IF you have transmission already, save the money from new from the dealership and get something is going to work with the type of driving you plan to do. The reason why the OEM LSD is not optimal is because it does not engage the secondary part of the differential until the wheels are turned. In other words, it will almost act like an open differential until either the wheels are turned, or the torque steer allows the wheel to turn, in which only THEN will the LSD activates. If you want one that is much more able to handle the abuse of your GT3582R build, use a Helical LSD such as a Quaife, MFactory, or WaveTrac Limited Slip.
If you plan to circuit race the car, or something to that effect (AutoX or even Time Attack), then you need a mechanical CLUTCH-type LSD, such as Cusco, Kaaz, or the MFactory Clutch-type.
Here are the differences you can read up on. You don't want a Detroit Gear Locker or "spool" in this case
http://en.wikipedia.org/wiki/Limited_Slip_Differential
As for your Transmission choice
A GS-R transmission with a GS-R Engine is optimal, because it can keeps its acceleration rate due the 4.4 final drive already in the car, and there is no need to downshift 2 gears to get any type of powerband as with the LS. (Don't fall for the myth that LS "keeps you in boost longer". YEs you hear the turbo spooling up, but you're not really going anywhere...Especially in a GT3582R.
Here is the transmission Gearing chart on the Major B-series engines. I strongly suggest keep your GS-R and put the money towards a proper limited slip differential and not worry about the "JDM" versions of the transmissions for this type of engine build.
I think I've given more than enough info for you to go on to start here. ;-) Good Luck.
If you are going to be drag racing the car, then you can calculate transmission from the mph based on your power and tire size. You want to work it so that you pass through the traps as high up in 4th as you can. With your setup it seems like a gsr tranny with some 24.5" slicks is the best bet, putting you at the ebd of the 1/4 mile in the mid 8000rpm range.
I make similar power to u, (a little more on pump, less on racegas) and am using a gsr trans with mfactory lsd. It kinda is a little crappy cruising at 75-80mph, but is great for matching my engine's powerband.
Don't get an ls tranny, mathmatically its not accelerating as much as a vtec trans. U can use a b16 for the track but I think you will likely have to spin the engine low 9000 rpm range. Whatever you pick, a good aftermarket lsd is pretty much a requirement
Moderator
LS is HORRIBLE without some sort of additional final drive. B16/ITR are great for street/ time attack, and all around. As for what's best for drag racing strictly...... ask someone else, because that's not my area of experience. ;-)
Shodan, thank you for detailed answer. Sadly I have an LS. I will be searching for GSR, and an LSD for it. I am still a little confused though. Are you saying the OEM unit, which is a Helical type (according to Acura) is inferior because it cannot handle the power? Or...?
Moderator
Also, don't fret about the LS transmission. that is an easy fix without having to sell what you have and buy another one, or swap out a lot of mix-matched gears. for over 300-500whp, the only thing the LS transmission needed to be effective was a change in final drive.
In your case, you don't need to change any actual gears themselves, because the shorter final drive (I highly recommend the MFactory 4.785 Final drive designed for B16/LS transmissions) actively shortens the other gears down at the same time acting as a torque multiplier (not actual torque but added torque in the powerband as you go through the gears) and simply use that.
for my Time Attack car, I had an older LS transmission as my original GS-R was given to my brother. after going through about 4-6 gear set change ups, the best method wound up being the simple; 4.785 final drive, and ultimate a GS-R 3rd gear (because of the circuit tracks I ran sort of needed it), and that's it.
So, cliffs:
1. No, your OEM LSD will not work the way you think it will. It won't break, necessarily, but will not work properly either. It's time for Helical from Quaife, Wavetrac or MFactory
2. Its ok to have an LS transmission, all you need to do is purchase a shorter final drive
3. I recommend the MFactory 4.785 final drive made for the b16/LS transmission as they have the correct bolt pattern without having to modify it for a OEM JDM 4.785 FD.
this says its helical: http://www.acuraautomotiveparts.org/...s=&view=normal
My helms manual says its helical as well as mys Acura type r technical guide
Moderator
Sorry. My apologies. I didn't see you wrote own and helical. I retract my statement
Ok glad we are on the same page . Ok I am debating keeping the LS with the lower FD and added LSD but... the LS will still have the same gear spread, wont this cause the tranny to still be less advantageous than the GSR?
Agreed for street driving and time attack ITR or B16 is the better choice as the LS is to long for that type of driving. The LS trans would keep you out of the power band after shifting. I was thinking for drag racing the LS is a better choice because the longer gears keep you in boost longer for the straight run, plus if running from 15-11's ET you trap in 4th gear. Less shifting= more time in boost and in power. The GSR with a good LSD is the best compromise middle ground trans.
Moderator
I keep saying this over and over again. 1) being "in boost longer" doesn't mean anything with this kind of gearing because YOU ARE NOT ACCELERATING ANY FASTER than with a GS-R transmission ( unless you use a shorter final drive).. That does not work.
If you keep the LS transmission, please change your final drive as it affects ALL of the gears in a positive way. Yes. Even in drag racing
