temp turbo bypass
Old Dec 15, 2011 | 11:56 AM
lazy14's Avatar
Default temp turbo bypass
i have a 90 dx hatch with d15b7 bottom end n b2 top end with turbo, blew seals in turbo n need my car, i bought it with the turbo, its obd0 with chipped pm6, to get drivable n back to stock for now while i order parts if someone would let me know if im wrong but i have
pm5 mt ecu
stock obd0 injectors (still has resistor box)
stock exhaust manifold
i know i need to plug the oil lines and vacuums, but is there anything else i need?
Old Dec 15, 2011 | 12:08 PM
4drEF's Avatar
Keyboard Humorist
Default Re: temp turbo bypass
The PM5 is for a DX - Dual Point rather than Multi Point
You needed to buy a PM6.
-OR- You could get a chip made with a stock PM6 map -but- with support for the larger injectors that you have for the turbo.
-OR- just have a stock PM6 map made and use the stock OBD0 injectors and box.
You could also just bolt in some pipe in place of the turbo, but replacing the whole manifold works too.
Also need to deal with your intake arm and filter.
Old Dec 15, 2011 | 12:28 PM
lazy14's Avatar
the idiot before me welded the turbo on, so even tho its mpfi converted i cant use the pm5? srry i know a little been readn n learnin, but i still dont know that much.
Old Dec 15, 2011 | 12:33 PM
TearSDMF89dx's Avatar
the car is mpfi now so you can no longer use a dpfi ecu
Old Dec 15, 2011 | 01:09 PM
lazy14's Avatar
k thanx
Old Dec 15, 2011 | 03:15 PM
lazy14's Avatar
so i got a obd0 pr4, hopefully it will work, n wants the new turbo manifold turbo n waste gate get here im getn it tuned then ill post pics
wakn
Jan 10, 2014 05:38 AM
highazamotha
Feb 7, 2010 06:48 PM
zx2gotboost
Dec 19, 2005 07:33 PM
ham
Oct 28, 2005 04:40 AM
