walbro intank with 044 bosch inline pump
Old Dec 6, 2011 | 02:07 PM
boosted.si04's Avatar
Default walbro intank with 044 bosch inline pump
Ok Im seeing if theses pumps will get me around 700 whp? I will have the engine, turbo and 2000CC ID injectors for it on e85. So is this doable or will I have to upgrade the 255 walbro to the new 400 walbro? Thanks.
Old Dec 6, 2011 | 07:02 PM
imptricer's Avatar
Default Re: walbro intank with 044 bosch inline pump
just run dual 044's if your going the e85 route
Old Dec 6, 2011 | 07:06 PM
Well I already have the pumps so I was seeing if it's possible with higher fuel pressure if needed as well.
Old Dec 7, 2011 | 08:46 AM
Then since im only going for 700 should I go with lower injectors? Cause I not gonna go over 700 what u guys think? Any input is appreciated
Old Dec 7, 2011 | 11:20 AM
uglyasscivic's Avatar
the 255/044 combo with those injectors you should be fine. Make sure you have good voltage to both pumps and it will help tons.
Old Dec 7, 2011 | 11:32 AM
Okay awesome thank you! I was thinking about getting a new were fuel pressure reg. the new fuel lab one good cause I have a aem one that doesn't hold like high fuel pressure.
turbolsvtecej1
Sep 7, 2014 04:06 PM
EG-SIXV-TEC
Jun 14, 2012 12:33 PM
Mike Lowwryyy
Jan 25, 2012 08:37 AM
Anubyss
Apr 23, 2003 06:54 AM
HybridCoupe
Jul 6, 2002 04:44 AM
