car cuts out in boost
Old Nov 29, 2011 | 08:37 PM
texx72's Avatar
Default car cuts out in boost
hey guys my car is cutting out in boost and i cant figure it out. ive changed plugs and wires. new dizzy. car is getting fuel. it cuts out at anything over 10 psi mostly. my set up is garret 57 trim. tiel bov and waste gate. dsm 450s and a aeromotive fpr any help will help lol.
Old Nov 29, 2011 | 08:39 PM
Dc4LsTeG's Avatar
EK9
Default Re: car cuts out in boost
Tuned?stock map sensor?
Old Nov 29, 2011 | 09:07 PM
ev94eg's Avatar
yes maybe map because stock cannot handel over 10.68 psi i beleive
edit: and u said it cuts out after 10 psi so give us more info on ur setup
10psiLsEf2's Avatar
Old Nov 29, 2011 | 10:26 PM
texx72's Avatar
its tuned on chrome and its stock map but this is the first time ive had a boosted car do this. this is the 3rd boosted honda ive had and all had stock maps. i can try that nd see if that fixs it.
Old Nov 29, 2011 | 11:08 PM
Dc4LsTeG's Avatar
EK9
Has it always done it or did it just start doing it after working normally?
Old Nov 30, 2011 | 12:06 AM
Mike Lowwryyy's Avatar
What boost levels were you running on your other boosted hondas with stock maps?
Old Nov 30, 2011 | 12:12 AM
Dioxine's Avatar
Boost leak would be my first guess. Build a boost leak tester.
Old Dec 4, 2011 | 12:46 AM
texx72's Avatar
well i figured out what was wrong. it was the ecu.. dno how but it was lol
Old Dec 4, 2011 | 02:00 AM
Dioxine's Avatar
At least you got it fixed. Good job.
Old Dec 4, 2011 | 03:41 AM
grumblemarc's Avatar
The Grumpiest
Wha? At least explain HOW it was the ECU.
Old Dec 4, 2011 | 08:37 AM
b16bri's Avatar
Yes please explane how it was the ecu and what you did find that out. I'm a little skeptical about your boosted honda being able to run over 10psi an a stock map
Old Dec 4, 2011 | 08:38 AM
Gsrsi's Avatar
but if stock map sensors can only read 10pounds how...is it working.
Old Dec 4, 2011 | 09:32 AM
komat's Avatar
i bet it was a cold day when he was getting boost cut. then when he thought he fixed it , that day was warm
Old Dec 4, 2011 | 09:37 AM
Gsrsi's Avatar
why do u say that?
Old Dec 4, 2011 | 09:42 AM
The Grumpiest
Physics?
Old Dec 4, 2011 | 09:43 AM
Gsrsi's Avatar
thinner air?
Old Dec 4, 2011 | 09:46 AM
nealnanoHX's Avatar
Pretty sure the stock map can only read 10.8 or 11 psi of boost. Cold day more dense air= slightly higher boost level= fuel cut??? Sounds possible to me.
Old Dec 4, 2011 | 05:51 PM
BoostedDOHCGSR's Avatar
10 Year Member
stock map wouldn't do that unless its told too. It is my understanding the stock map would simply run the last fuel table to anything over 10psi.
Old Dec 5, 2011 | 04:43 PM
texx72's Avatar
ive never had a boosted honda with a aftermarket map. im running 15 pounds. idno how the ecu messed up but i got a good deal on a ecu with the new neptune software on it so i put a basemap on it and it fixed it. im guessing some how the chip in my old ecu messed up some how. ive never had a problem running 15 pounds. i know its prolly not good for it but my last boosted civic went 2 yrs on 15 pounds all stock and the motor had 200k + on it
Old Dec 5, 2011 | 04:46 PM
LightningTeg's Avatar
Community Builder
Old Dec 7, 2011 | 08:12 PM
aut0m4tic's Avatar
If you look view the options (press F4) in Crome you will see a box than says boost limit and the measurement is in mbar. Raise the number and you raise the boost limit. Just make sure your tune will support the added air flow.
Old Dec 7, 2011 | 09:10 PM
turbohatch96y7's Avatar
Im thinking you had a boost cutout set and this new ecu doesn t so now all that boost spoking is gonna blow that motor even faster....
Old Dec 7, 2011 | 10:08 PM
W!d3b0dYr3X's Avatar
i was going to guess spark plug gap since no one mentioned it, but if you say you fixed the problem then i guess you fixed the problem.
Old Dec 8, 2011 | 08:55 PM
texx72's Avatar
it all a sudden happened. i dont drive it daily. the bottom end is built it will get a diff map and a new tune in the spring. im not worried about it if it blows it blows lol
Hiboost 2.0
Apr 17, 2013 08:14 PM
97grnrs
Jan 9, 2008 09:57 AM
the.hamburglar
Aug 2, 2007 02:44 PM
Crazy Cooter
Nov 4, 2003 05:02 PM
99lspwr
Oct 24, 2003 09:12 AM
