oil pressure gauge
oil pressure gauge
First off this is my first time posting on Honda-tech please let me know if anything in this post isn't up to par well I'm building a turbo gsr setup I am thinking of running an oil pressure guage I have been playing with civics and integra for a while now and never had a problem with the oil pressure warning light it has always done what I needed it to do I just don't want to buy a gauge if I don't realy need it thanks for any advice!
Premium Member
Re: oil pressure gauge
Oil pressure warning light is more of a dummy light anyway...The only time I've ever seen it come on is when there's not even enough oil to show on the dipstick...depending on the condition of things, by the time the light even comes on you could have already done serious damage to something. An oil pressure gauge isn't a must obviously but it's helpful and handy to have. So no, you don't really need it. But if you want to be more "in the know" about what's going on inside your engine, I'd recommend one. Mechanical is fine, and they're on the cheaper side. Just make sure whoever installs it knows what they're doing, wouldn't want to blow a ferrule out and screw up your motor. Or if you're uncomfortable with running an oil line into your car, electrical gauges aren't much more but they're not as accurate.
Gauges I ran on my last turbo build:
Oil Pressure
Wideband O2
EGT
Boost/Vac
All of them proved to be extremely useful in both tuning and diagnostics.
Oil Pressure
Wideband O2
EGT
Boost/Vac
oil pressure guage is a must on a turbo'd honda.....the dash light comes on a 0psi....thats right it only reads if there is NO oil pressure
what you NEED:
oil pressure
boost/vac
wideband o2
highly recomend getting;
water temp (stock sucks) i'd almost add this to the need
egt
get mechanical gauges....
what you NEED:
oil pressure
boost/vac
wideband o2
egt
da9carl
03-12-2011 05:13 AM
