6266 and 6766 Dyno numbers and Spool?
Old 12-09-2011, 01:36 PM
Steeve_Civic's Avatar
Default 6266 and 6766 Dyno numbers and Spool?
Do you have some Dyno sheet with 6266 and 6766?
What are the spool difference with same AR? 1000rpm?
Old 12-09-2011, 04:39 PM
Moderator
TheShodan's Avatar
Default Re: 6266 and 6766 Dyno numbers and Spool?
The XX66 turbine wheel is a bit too new for anyone to have such a comparison, for a given engine. Engine size, rpm, A/R all play a factor.
Give until next Spring here in the U.S... then you'll find some results to compare to. Suffice it to say, its for those that want over 500whp on a lower amount of boost for the 6766 and is for drag racing only, really.. not too much street use.
Old 12-12-2011, 06:47 PM
RoadconeTuning's Avatar
I've yet to see any numbers from a 6766... I figured we'd see something by now
Old 12-12-2011, 07:01 PM
sanman000719's Avatar
give me a month ill post some
Old 12-12-2011, 08:25 PM
Casey's Avatar
search google. i found a 6766 vs 6765 on evo and supra. the 66 wheel is making 80+ whp more.
on the supra, they compared a 6266 to a 6765 as well. the 6266 had a fatter powerband and made more power up top
Old 12-12-2011, 09:21 PM
Moderator
TheShodan's Avatar
That's not really because of the exhaust wheel. There's a bit more to it, including but not limited to the amount of boost pressure used per range. Its hard to do "back to back" to jump to such a conclusion.
Just be patient, people, real results will come soon.
Old 12-13-2011, 11:46 AM
i found a few shops that had done dyno comparisons... generally the new turbos made 30-50hp more once spooled at the same level of boost... STM had comparisons using an EVO VIII
darksolguy
12-03-2007 04:05 AM
94vtirozguy
07-25-2006 02:03 AM
Norcalstoppy
09-28-2005 06:48 AM
hooptie157
Honda S2000
09-17-2002 12:51 PM
Quick Reply: 6266 and 6766 Dyno numbers and Spool?
