Need More than 750cc injectors?
I need to change my 750cc Injectors High Impedance.
Is there some 1000cc injectors High impedance?
or do I need to buy a resisor box and low impedance injectors?
If so is there a resitor box kit plug and play?
Thks
Thks
Moderator
Re: Need More than 750cc injectors?
Sorry for the lack of response on PM.
The Injector Dynamics (ID1000s) injectors which are high impedence, and don't require a resistor box
Fuel Injector Clinic (FIC 1000s) also has high impedence injectors that don't require a resistor box.
Rochester/Lucas, (RC Engineering), and the older Precision (Delphi) and Newer Precision (Siemen Deka) injectors all require a resistor box in order to install their 1000cc injectors.
Ok Shodan no Problem Thks :-))
What do you think about resistor box?
I don't think I will need to upgrade over 1000cc. Are 1000cc high impedance good?
Moderator
I use a resistor box for my Siemen Deka Direct injectors, and I find nothing wrong with it, because we had a resistor pack already in there..
With changes in technology, its better to skip that step and go with either the Injector Dynamics (ID1000s) or Fuel INjector clinic (FIC1000s) as they both great companies to get injectors from. H-T is a bit more biased towards the Injector Dynamics, but they both work just fine. Make sure you have a high enough volume fuel pump to run them. At least a Walboro 255lph is needed.
Thank you.
Do you mean you have a resistor pack OEM and low impedance injectors ?
I will run 2 Walbro in the stock Fuel Cell
Okay.
If one fails, I can see it on the Fuel regulator?
I'm running like that on my Supra MKIV since 6 years without problems.
I gonna looking for 400lph Walboro
skeetahendo
03-15-2008 03:44 AM
